Viperguy
Everything posted by Viperguy
  1. I had to drill a couple small holes in order to run the wires through the plug.
  2. I had thought about doing that but since I'm running an amp with this, I wanted to run the larger wires. I was finally able to get that plug undone with some force and just ran the wires through the empty spots in it.
  3. I'm going to be installing a component speaker system in the front of my '07 Edge. I noticed in the door jam there is some sort of "plug" with the rubber conduit that all the wires run through into the door. Does anyone know how to "unplug" that or is there an easy way to run the aftermarket speaker wire through there. The rubber conduit makes a big loop so I don't think it I could feed it through there like it is. Thanks Viperguy
  4. I've got an '07 Edge SEL fwd. Was looking at getting a catback exhaust and noticed there are two different Magnaflow part numbers. One is 16750 and the other is 16871. I'm not sure what the difference is, but it appeared that maybe the 16750 was older or something. Anyone know? Thanks Viperguy
  5. I've got an '07 Edge SEL with basic 4 speaker sound. I'm installing an aftermarket headunit and was wondering about the three plugs of wires that are plugged into the stock radio. I'm using the Scosche harness which is the FD23B. I know that the large plug is the main one which plugs into the Scosche but what about the other two. I think one is for aux input but not sure about the other. Can I just leave those two plugs not plugged into anything? Thanks for the help Viperguy
