Chas.
Everything posted by Chas.
  1. 2010 Edge. There's an indicator panel next to the floor shifter. As most, it indicated P,R,N,D,L. However, at night this panel can't be seen without turning on the map light. Is there a light bulb under there that's burned out, or is it just not lit.
  2. akirby, you were ever so close. I don't think you can set DRM on MP3's, but I took a look and found the Archive bit as well as the Read-only bit was set on those files. I turned both bits off of them all and they play just fine now. Thanks for getting me headed in the right direction.
  3. Here's the particulars - 2010 Ford Edge w/up to date software. Kingston 2GB USB 2.0, with 261 MP3 audio files, about 3/4 full. I plug in the flash drive while engine is running and go through the convoluted menus to get the audio system to access the USB drive. It says "INITIALIZING" for 1.5 - 2 minutes. Then the message appears "UNSUPPORTED" appears. Am I feeding it too many songs at once? Is there a maximum?
  4. Just joined this forum. I live in E. Tennessee and just bought a slightly-used 2010 Edge. I suspect I'll have some questions, especially about Sync. This looks like the right place for solutions.
