Alright, replaced both rear bearings and I'm back to a quiet ride again.
My phone was on its last leg of battery so I didnt get pictures. Here is the scoop;
First off you need a shop to do this in, theres a variety of tools I used.  A lift and a jack to lift the arms to reconnect etc. Anyways,
The trailing arms have to come off.  First loosen up the Ebrake adjustment Leave the adjustment nut on, 2-3 threads left. Its under the drivers seat area, chase the ebrake line.
Ok, wheels, calipers, discs, axel nuts, e brake cable, and ABS sensor,  remove and disconnect them, I put a zip tie through the caliper and hung it off the bracket in the upper left of the wheel well just outside the spring. With the car lifted by the frame so the suspension is at full extension, loosen, NOT REMOVE, the connections on the trailing arm for, Shock, spring arm (dont know what its called, main suspension part with the spring), a smaller control type arm, I believe it is used to control wheel camber (this one you will want to take good note of the oblong washer and where it is bolted. If it goes back in the wrong place your alignment will be all messed up. And loosen the upper control arm on top.
    Put a jack under the trailing arm where the bumpout is for the spring arm, lift the suspension do not lift the car off the lift but the higher the better, the upper control arm is in continuous tension with the trailing arm and wants to spring up as soon as you unbolt it from the trailing arm, With that removed, drop the jack back down, lift the suspension an inch or so to relieve pressure on the shock connection. remove that bolt. (also As I was doing this I was applying never seez and putting the nuts back on so I wouldnt get them confused)
sway bar link forward of the axel on the trailing arm, bolt requires an allen wrench in the center to hold the bolt and slip a box wrench over to remove. Now with that bolt out the ebrake cable is free, you can tuck that out of the way.
   There are 5 bolts holding the front of the trailing arm onto the frame just forward of the wheel well remove them.  two of them are longer than the other three, two long bolts go closer to the center of the car, shorter bolts are front center, and the two outer bolts. If you tucked the ebrake cable out of the way, then its out of the way! So lower the jack all the way, slowly. remove the last two connections, spring arm and smaller control arm. its not going to drop off, you will have to wiggle it off. tapping the axel back through the bearing and  some yanking and twisting and maneuver it out.
four t-60 bolts on the back side. remove  them. My hub units were corroded on pretty good, one whack with a hammer and trailing arm was off.  took the hub unit with the ebrake assembly, ebrake side down,  and I put blocks under the ebrake pads and put the four bolts back in halfway to allow me to use a hammer to hit the bolts and separate the hub unit from the rest of unit. you will notice it moving slowly, go in a circular motion one hit per bolt otherwise it wont come out, has to be even all the way around.
Before you start putting it back together remove the "control arm" , that small arm that connects on the lower side of the trailing arm forward of the spring arm, from the frame. as I said before Pay attention to where it is, Mine hadn't been moved so it was obvious where the bushing was. remove the nut, and tap the bolt back through, dont unscrew the bolt.
Now its all apart. Never seez everything upon reinstallation. When you reinstall the trailing arm you do it like this. (first one took me 4 hours break down and reassembly, second took 1.5 hours.) feed the axel into the bearing (NEVERSEEZ! everything!@) Align the spring arm connection first, pain in the neck but patience is a virtue. slide the bolt through, and finger snug onto the nut. Next get the jack, with a rubber or wooden block lift the trailing arm from the wheel studs, 3"-5" this will allow easier allignment of the front of the trailing arm, the part with the 5 bolts forward of the wheel well. you might need to pull it a but to get it to line up. Tighten them up. Let the jack back down and raise the trailing arm back up and align and put the shock back on, then keep going up so you can reattach the upper control arm. I raised the trailing arm until the upper arm was just about touching the top of the trailing arm, align that and bolt it up, you might need a screw driver or something to push the trailing arm out or in. Let the jack down to allow you to  reconnect the sway bar link with the ebrake cable clip. Then take the smaller control arm you completely removed and fish it up and back into place. It goes from the lower connection point on the trailing arm OVER the sway bar and into its connection point on the frame. I found it best to align the bottom and slide the bolt through, then align the top and slide the bolt through, THEN tighten up the bottom. then tighten the top, Again make sure the oblong washers and bushing are where they should be. Tighten the nut not the bolt, tightening the bolt will move the bushing forward and back.  reconnect the abs sensor, ebrake cable with two bolts, I dont believe Ive forgotten anything on the reassembly,
 reassemble the brakes, axel nuts, and you are ready to go. Retighten the ebrake cable underneath and hell, while your at it rotate the tires. The pattern for reassembly seemed to be far more important. That is the only way It would reassemble. taking it off didnt seem to matter.  any questions shoot me an email.
