voodoo_ca
Everything posted by voodoo_ca
  1. What if the hub bore size is bigger than the one on the car? It looks to me that it will be 67mm on the rims while the car is 63.4mm - my instinct says that will sit over the hub. The explorer that these came off of was 70.5mm. comments?
  2. Thanks Is973800, I will have to check that hub bore size. Regards, Chad
  3. I wanted to first thank everyone here for all the information that I have gleamed from the site over the last while - There are many questions about this topic, and I have been reading them. This involves changing the Sport 22"s to something for the winter. Here is what I have gathered so far: Should be able to go down to a 17" rim as the smallest that will still fit around the calipers. 245/70/17 seems to match the sizing of the stock 22"s so I don't have to worry about speed changes. I have found someone with a set of these Sacchi S62 262 rims for sale that he said were on his 2007 Ford Explorer. Now I am trying to determine if everything else will work. First I tried looking up the tire sizes online and thought I found that both were 5x114.3 The only problem was I couldn't find anything on 2013 Edge Sport, only a few years older - but I thought it might be the same. I just did the Canadian Tire fitment wizard online - it did say that can use 22, 20, 18 or 17 rims. When it gave me back the choices, the above rim was included - but they gave 17x7 5x100 bolt pattern. Either that's the same OR something is wrong - is the 2013 edge sport 5x100 or 5x114.3? It says Bolt Pattern 1 5x100 bolt pattern 2 5x114.3 - do they have spacing on the same rim to make both of those work, or 2 different rims? I also did an online offset calculator to see what difference that would make on the rim. Form what I gather the 22"s are 9.5" deep and have a 35mm offset while the new ones are 7" deep and have a 40mm offset. If I understand correct, the rim moves 31mm away from the inside of the vehicle - giving more clearance - and 33mm away from the outside of the vehicle. Does this difference cause any problems? - it looks to me like it should be ok. Thanks for the support everyone! Chad
