Omar302... Amazon says for the puddle & dome lights do not fit. I have 2011 Edge... is amazon not able to convert the led light number correctly ? Are the links you provided legit for the 201 Edge? Interested in purchasing them if they fit.
Do you have anything modified in the engine like a cold air filter? I just started getting it as well but only after installing the k&n cold air intake. It comes in occasionally on the highway but not reg city speed.
I have a 2011 Ford Edge Limited and considering the Husky Mud Flaps. They appear to have a nice accent to them and advertised as "no drilling needed".
Haven't found a pic that shows the overall look after install either on this site or the web in general.
Please share if you have them. Thanks
Hello all .. haven't seen this topic in any recent threads but I'm looking for recommendations on the best kit to buy to switch out the factory dome lights and under the side view mirrors light with LED. Any recommendations?
thanks .. I'm stumped and not convinced the cold air intake is to blame although the swishing of air is suspect since the cold air intake filter is pointing to the left and the swishing / discharge of water occurs only on left hand turns. Is the a/c evap drain easy to service myself or is a dealer needed?
Just noticed water coming in the passenger side around the fan area when specifically making a left and turn. There's a swish sound when making a left hand turn...almost sounds like air being forced through the system then the water comes out.
I recently installed a K&N Cold Air intake system and had not noticed this issue previously ..although it could have existed.
Any one experience this before either in general or after installing a cold air intake system?
Is it clogged lines or censors causing the water build up and discharge?
