ashvan017
About ashvan017
ashvan017's Achievements
  1. Just an update on this, I had to get all new pads (both front and rear) and all new rotors (both front both rear because machining them was not working) and also had to replace a sticking caliper in the rear. So far no noise. I just got that all done on Tuesday so will keep you updated. Thanks for all the updates!
  2. Yes please do let me know. My car is at Ford right now and they said I need new rear rotors, new rear pads, and a new rear caliper. But the problem is, the squealing is coming from the front not the rear. They STILL said they can't gaueantee that this will fix it. So basically if I pay for all of that to get done and it doesn't fix it then I'm just out of luck and have to keep paying til it's fixed. Please let me know if you get yours figured out!!
  3. Did your squealing in reverse go away after they put on the new rotor? I can't afford to put a new rotor on and not have the problem corrected!
  4. Did you have the same issue? I'm almost 90% positive that they already bled it, but need to check. They've done A LOT of work to my car.
  5. I called. I was surprised.. I didn't have to wait at all, I was sent right to a customer rep. And they filed the complaint for me! The more people, the better.
  6. Thanks for the quick reply! If I were you, I would file a complaint with Ford. I filed a complaint today because it can't be just me that this is happening to. I got a "case" number and hopefully I'll hear back shortly. I am sick of being in and out of the dealership and tired of spending money replacing pads, rotors, etc. hopefully I find a resolution. Let me know if you hear anytbing too! Thanks!
  7. Oh my gosh. I am SO HAPPY someone finally posted this. I am having the same issue with my 2011 Ford Limited. My brakes are only squealing in reverse but not in drive. I had my brake pads replaced 3 times since March. I had my brake booster replaced as well. Someone please help!!! I am on my 6th trip to the second Ford dealership and they're all dumbfounded. They have no idea how to fix the problem. Did you get your problem fixed? Please let me know!! Thank you sooo much for posting this!!
