bRADen
Everything posted by bRADen
  1. Has the stock two wire (pos) + (neg) and a single yellow for the amber. Found the blinker pos and it turns off the w&ite light and flashes amber. When blinker is deactivated the the entire light gies off. If I remove the blinker pos the white light cones back on.
  2. I got some switchback vertical DRL's for my '13 edge limited. Came with no instructions. Perfect fit wire harness clicks right in for the drl. The amber blinker has a single wire to hook up to a blinker wire. I found the wire on the headlamp running lamp flasher and the amber blinker works. When the bkinker then is off the regular white drl does not come back on. Anyone know what wire to tap into to make these work properly? Thanks in advance!
