Everything posted by Jei
Thanks buddy, I use plasti dip as primer and then plasti dipped rims I repainted with car paint, all that because if I ever want to remove white paint and still have chrome rims I can easily remove it because of plastidip )))
Quick time lapse of oil change on my Ford Edge 2012 (project Yeti) https://www.youtube.com/watch?v=eHRS3mmUps0
Thanks, already order spark plugs, transmission fluid Motorcraft Mercon LV and PCV valve. How is better to clean it? use mass air flow cleaner or disassemble TB and then clean?
Thanks for reply. I will try explain as much as possible. On low speed when I hold gas pedal in one position and transmission shift from one speed to another I feel little delay or sometimes no delay but a little kick. Another issue is when I accelerate little bit aggressively and then abruptly let go gas pedal I feel kick. That's the problems that I have. About kick on traffic lights, I never feel that car sways with climate control off, but when it's on, sometimes it's so terrible , car sways back and forth. BTW thanks for info about spark plugs & PCV valve I didn't thought about them.
Thanks guys. Today I checked transmission fluid level and was really surprised fluid is in perfect level and it's clean like brand new, I don't know what to do now... Unfortunately I don't have any information about it was replaced before or not and I have almost 80K miles, I really don't like how transmission shift on low speed. Maybe problem is not in fluid? :doh: Sometimes with climate control on in auto mode when I'm standing on traffic light I fill kick, this kick is so strong that car sways, plus today I hear hiss noise from braking pedal, I think I have to replace brake power booster and I thought maybe that's why transmission going crazy? or maybe my AC compressor is dies and that's is the reason of this kicks? I do not know what to think HELP NEEDED :hat_tip:
Thank you but it's not work for me, in Philly is only one gas station with 110 Octane :D Thanks guys, today I fill up my car with 87 I even don't remember when I used it before )))
Thank you. BTW, I don't want open a new topic and I will ask here, What fuel do you use guys? I know that I can find this info in owners manual but I want to hear this info exactly from owners. I use 89 should I continue use it or better to use 87?
Now i see, thanks. Thank you. Can anyone tell me this fluid good for transmission? http://www.ebay.com/itm/Ford-Motorcraft-MERCON-LV-Automatic-Transmission-Fluid-12-Quarts-Free-Shipping-/191658451117?hash=item2c9fbbe0ad:g:naUAAOSwT6pVyOM2&item=191658451117&vxp=mtr thanks.
Thanks. I'm sleeping better after I changed oil by myself
Thanks for answer, no my car is 3.5L. Okay so i will continue to use Motorcraft engine oil and will choose same brand for transmission. But what's about fuel filter i have to change it with fuel pump or it's good until pump is in work condition? Thanks.
Good time of the day. I'm new member of this forum and owner of Ford Edge 2012 SEL, I own this car for about 3 month and I'm pretty happy to own it. I searched for info about filters, liquids and found this great forum. My first question is: Oil for engine, I changed oil about month ago, I used Motorcraft 5W30 as recommended, I want to hear your opinion about this oil, is it good or not? or maybe is better to change on another oil? Second question: Transmission oil, I read that oil in transmission should change on 150K miles, is it true? I have almost 80K miles and I think that it's time to change it, because I don't like how transmission shift on low speed. I want change oil by myself, i found info about changing oil in transmission but I can't understand is there no oil filter? I have to change liquid only? plus can someone tell me which oil to use? Third question: Fuel filter? no fuel filter? Help needed thanks in advance!
From the album: Yeti
© Jei
