Msnapper
Everything posted by Msnapper
  1. Yeah 11 owners manual Says to reset go key off to on 3 cycles
  2. I've never noticed if tach displays when cranking . I'll check tonight
  3. 13.5 was voltage the previous time it happened after it was running.
  4. Battery voltage was 13.5 and while I don't have a tach, it doesn't seem slow cranking
  5. I swapped relays and change fuse. Is there a filter in the system. Is the inertia switch that shuts off pump in accident contained in fuel pump control module?
  6. 127k I don't think it has a test port on the rail to check pressure. I've tryed to listen for pump can't hear it and also disconnected it at Rail and cranked engine,no fuel came out so I assume pumps not priming
  7. Recently I've had issues with the car cranking but not starting. I've changed the fuel pump controller and car ran ok for about a month now it's doing same thing again. No codes when scanned,and no check engine lights
