tiguanito
About tiguanito
tiguanito's Achievements
  1. Same issue with the first camera I bought on ebay, image upside down and no calibration possible. I have returned it and bought this one : http://www.ebay.com/itm/FORD-OEM-11-12-Edge-Rear-View-Backup-Back-Up-Camera-BT4Z19G490B/162171150605 More expensive but is OEM, and works perfectly fine on my 2012 Edge.
  2. Not sure here 's the description: "We Purchase The Item From Factory With OEM Quality Description: 2011-2013 Ford Edge Lincoln MKX Rear Reverse Parking Camera BT4T-19G490-AF BT4Z-19G490-B" Maybe not OEM. There's quite a lot of choices on eBay, not sure which one to buy next. Has anyone replaced with one from eBay recently ?
  3. I tried yesterday to replace the camera on my 2012 Edge (Limited , FWD V6), with this one : http://www.ebay.com/itm/US-Rear-View-Reverse-Backup-Camera-BT4Z19G490B-For-Ford-Edge-Lincoln-MKX-2011-13-/162562036227 The image was upside down, and I couldn't calibrate it with ForScan. My old camera can still calibrate but disconnects frequently. I will return it, but wonder why it didn't work. Is it because it's a Gen-2 ? There's a lot of BT4Z19G490B's available now but not sure which one to order now. Any recommendation ? thanks.
  4. tiguanito
    IDS/Scan tool?
    I have the same camera issues on my 2012 Edge (lost the lines, etc). I would like to order an OBDII adapter to try to re-activate it and see if it will lose the signal again. I'm still unsure if I need the more expensive OBDII MX ($80) that supports MS-CAN, or a cheap OBDII without MS-CAN can work for that purpose (re-calibrate/activate the camera ) ? thank you
