AJF
About AJF
AJF's Achievements
  1. Thanks for the replies. I did end up running along the headliner, then dropped it down inside the rear panel, under the spare, through an access plug, under body and then between the tail pipes, through an access point behind the license plate, then attached the camera above the license plate. Pretty simple after removing the spare and seeing what I have to work with. Again thanks.
  2. Hi I'm new to this forum and I have a question regarding my wife's 2011 MKX. Figured I post an MKX question here since the MKX and the Edge are fairly similar. I got her a Rexing dash cam with rear camera, but I don't see an access point to run the wire from inside to the hatch door. I have a F150 truck and I have an access point on my driver's side floor to the left of my brake pedal that allows me to run wires outside and to the rear. I was seeing if the MKX has something similar or how do I run the wire from the dash camera to the hatch door. I have the dash cam mounted on the windshield to the right under the visor and then I have the power wire hard wired into the fuse panel. Now I need to run the camera wire. Someone have an idea or two. Thanks
