vigness
Everything posted by vigness
  1. BTW, FORScan accesses most of the vehicle programming, just not as much on the older vehicles. Going to try and get around to plugging in and seeing what I have access to on the Edge. Too many vehicles to remember what I can and can't access on each one.
  2. That pic looks like what we have. It sounds like no matter what there needs to be an interface of some sort. I could have sworn I downloaded the entertainment wiring diagram back then, but I can't find it now and my internet search skills suck.I popped the display off the other day, and it has a 12 pin connector with only six wires in it. Wasn't thinking and didn't pop the lower unit with the CD in it to see what connectors are on the back of it. Wouldn't surprise me if that's the brains of the system and the display is literally just the display. I have some 4x4 programming the stealership has to do on my Ranger, FORScan can't access that module on the '03. I plugged into the Edge a while back, and I seem to remember the back up camera option available, but probably should check again before I delve to deep. It always seems the modules I want to program are only available on the newer vehicles. Neighbor changed his lane flash from three to six no problem, it won't let me access on the 2012.
  3. That's what I thought my original research said, but I can't find any of it or the pin outs to connect it. It doesn't help that's been at least one of not two laptops ago. If you could point me in the right direction for pin outs and / or wiring diagrams I would very much appreciate it.
  4. My memory must be going with the hair color. I could have sworn there was the ability to drop the video signals in direct. But then again it doesn't surprise me to need an interface of some sort. And since the car is not wired for it, something like that would probably be our only option. Probably will go in the 'make sure the next one has it' category.
  5. Ouch, they are proud of that. Will have to give it some serious thought before I go that far for a car that may not be around all that long. Thanks for the info, I'll at least bookmark it this time.
  6. Have a 2012 with the small 4.2" display. Back when we got it I did some looking and thought I found a wiring diagram / pin out to add an aftermarket camera. Now that she decides she wants the camera added I'll be damned if I can find the documentation or a link. It has a 12 pin connector with only 6 wires in it. Labeled Part # CT4T-19C116-CD. One part of me says it gets wired into the display, the other says it gets wired into the back of the CD player assembly. Picture me scratching my head at this point.
  7. Okay, so as far as I know my Edge does NOT have the memory function, but the wiring looks to match the one that does. Having said that, Where is the drivers seat module ( DSM ), and what does it look like? First blush I would say somewhere in the vicinity of the drivers seat, but that would make too much sense.
  8. Left mirror is 100%, right is 50%. Have up / down but no left / right. Putting the control in my F-150 shows it working 100%. Temp connection gets left / right functioning so it's in the wiring. Thanks for the link, I'm new to the forum. Will dive into it this weekend if I have time.
  9. Treat ALL exterior glass with Rain-X. It seals the glass pores and Ice comes off in sheets. Don't hardly have to use the wipers ether. The harder it rains the more the water sheets off. I only use wipers in misty. road spray times.
  10. Does anybody have access to the mirror wiring schematic? I originally thought I had a bad mirror motor, then possibly a bad switch on the drivers door. Testing has proven that both the mirror motors and the switch are functional. It SHOULD be easy to trace the problem, but... the wire colors in the passenger mirror housing and the colors on the back of the control in the drivers door don't match! First off, I purchased the car used from a dealer, but the history shows only one owner previous. That being said it's possible something happened along the way and one of the doors could have been replaced. I know at a minimum i have at least two connectors to trace through, one at each door hinge. I'm betting there is something in between it goes through since the wire colors change. BTW, I found a diagram for an older model, but it had three wires at each mirror. I have four, two for up / down and two for left / right.
