Trnenergy
Everything posted by Trnenergy
  1. I have a 2018 Ford Edge SEL AWD. little over 100k miles. Had the slippage issue with torque converter and had fixed in September last year 2025. The other day drove to store then another location. Parked idled for 5 min. Went to back up and felt a slip, thought it was on ice patch. Nope huge puddle of something... transmission fluid. Parked car called tow to dealer that fixed it. Dealer is saying one of the transmission cooling lines came off. They reattached it filled fluid and mechanic drove in shop and seemed to behave based on mechanic with 30 years of experience. Anyway about $1300 in parts and labor need to order new hoses install... I don't have shop service manual but when they fixed the convertor do the lines need to be removed and if so could there have been some delayed issue when they re-attached or adjusted the hoses? I asked and they are saying it disconnected and hose did not split or rupture? I have not brought this up yet with service advisor yet since it happened end of day on Friday. Just looking for some opinions. It has to get fixed just wondering if I should question them, which I will, about previous work.
  2. Welp got it back from the dealership. So moral of the story is get OEM parts. Aftermarket ECMs didn't like something with the aftermarket fan assemblies. In the end fan motor assembly OEM and a used ECM (a lot cheaper) were used and all good. I actually got $800 ish back... Ugh
  3. Hi, 2008 Edge 3.5 SEL 175K miles Vehicle overheated and ended up being the left\driver side fan. Dealership replaced with NAPA Dorman assembly and also replaced ECM because it took the fan portion out.. WTF Anyway went to pick it up got it and check engine light was on. Mechanic said and showed it to me EVAP code and cleared it. I left and it came back on as soon as I started it again. Took it back and they ordered another aftermarket ECM from O'Rielly's and that ECM did the same thing. FORD ECMs are on backorder so that's why using aftermarket. They have the Edge still and can't figure out why code is showing. If they put the broken ECM back in no code but obviously cant use broken ECM due to fan control. So now mechanic is trying to debug and thinks the aftermarket Dorman Fan assembly is not to spec or bad. I said use the Dorman because at the time that was quicker and a little cheaper than the FORD. Next step would be to order FORD fam assembly and try. Anybody got 2 cents. I have some background in automotive industry and wrote test Software for FORD and other companies. Not sure if this some weird limit out of spec thing. I think they are trying. I can't imagine the the aftermarket parts be that wonky, but I've seen weird stuff before. They also have ready another FORD ECM that I'll get money back if they use that one, but talking to the mechanic I think he frustrated he can't get this to work. I feel that he is genuine about it.
