I have a 2011 Ford Edge SEL front wheel drive 4 door with 150k miles. I had an issue where the front end was making a "popping" sound when turning right or left. The dealership and another shop both wasn't fully sure what was causing the issue. Because they weren't sure of the issue, it was going to be a crap shoot of just changing parts until the issue was fixed. Thinking i was getting ahead on the issue due to factory parts being so expensive, i purchased a kit from Detroit Axle that came with 2 lower control arms w/ball joints, 2 sway bar end links, all 4 inner and outter tie rod end links w/rack boots plus both front complete CV axle shafts. The dealership installed everything and it cost me $800 in labor including the alignment. The popping was gone, but something didn't feel right. The steering in general just never felt the same. i wrote it off as being the possibility of new parts it could just overall feel different. After a month, the vehicle started shaking on acceleration. It wasn't real bad, but noticeable enough it made me concerned. I called up the dealer and scheduled a date for them to check it out. Was 3 days away, so i continued to drive it to work. In that amount of time it went from a small shake on acceleration to quite a bit worse of a shake, but almost seems intermittent at times. You feel it every time you accelerate but the amount it shakes doesn't seem to always be the same. It's at its worse when going around a 90 degree curve and acceling mid way through, then it becomes almost a violent shake. Bad enough a can of soda sitting in the cup holder splashes out.
	So i took it back to the shop, they looked it over and basically said what they said the last time, it was a crap shoot. They are blaming the new passenger side cv axle from Detroit Axle. So i agreed to have them change them. After replacing it for $500, the shake is still there. They are now wanting to replace the other side (another $500). Before forking out anymore money, has anyone else experienced this kind of issue? I understand parts can be bad brand new, but whats the chance both cv axles are bad? Is there anything else they should be looking at that would cause that kind of shake on acceleration? At low speeds you can't hardly feel it unless you are looking for it, it really needs a decent load on it in order to feel the shake.
	I'm just trying to get as much info as possible before i keep dumping money into this thing. Already at $1500 and looking at another $500 now.
	Any help would be greatly appreciated. Thanks!
