IM4NC
About IM4NC
IM4NC's Achievements
  1. I have a 14 SEL and was changing the puddle lights. When I was putting the light back in it stopped working. The other side was still working. Put the old back in and it would not light up either. Any thoughts?
  2. I have a 2014 SEL with 225,000 miles. I get a vibration while driving. You can feel it when you start but gets worse the faster you go. It seems really worse between 50 - 60 mph while pushing the gas. If you let off it settles down but still has a vibration just not as bad. When I turn to the right it is worse then when I turn to the left. Feels like driver side. I have replaced cv axles,struts and tires since they needed replaced anyway. Thought maybe bent wheel but rotated tires with sane result.
  3. I replaced both rear shocks and both rear sway bar links and mine went away. Shocks were $106 for both from Autozone and sway bar links were $38 for both from O'Reillys and replaced myself. Alot less than $500+
  4. It ended up being a rear sway bar link. After I ran the car for a few days the noise stopped.
  5. Yeah I was thinking the same. I did replace both shocks too. Forgot to mention that it was both.
  6. Changed the sway bar link and still have noise.
  7. Checked that already and nothing loose. I got a sway bar link today. Going to try that tomorrow. Will post results.
  8. I have a front wheel drive. My rear shocks are separate from my Springs I don't have a strut in the back
  9. I have a 14 Edge Sel and have a thumping/rattling sound when going over bumps from the right side. I was told it was a shock so replaced it. Didnt go away. Had it in the shop for another issue and the said samething. Replaced shock again and still have noise. Was told maybe a sway bar link. I added a sound clip of the noise. Any help would be greatly appreciated. Voice 001-1.m4a
  10. I did that and it worked. Thanks!!
  11. Horn is not working. I have checked the fuse inside and it is good. I noticed before it stopped working when I would set the alarm the horn would sound weak sometimes and sometimes would not make a sound.
