Cubflyer
About Cubflyer
Cubflyer's Achievements
  1. I am looking for the wiring diagram for the turbo system for my 2012. After replacing the valve cover I now have a p1013 code and have replaced both the turbo solenoids and still have an active code. Thinking maybe somehow I damaged the wiring and would like to check it out but need a diagram. Any leads where I can get it for free without paying for a service or purchase a book? thanks Jeff
  2. So I have been experiencing hot or burnt oil smell when I come to a stop. I have no leaks on the floor of my garage. Looking closely all over the engine I dont see anything that is leaking that I would feel is burning. The smell is more like a hot oil smell. Would a plugged pvc valve cause this problem? I never had this issue before I had a vvt seal completely blow out. After replacing the seal it seems as if the oil smell has never gone away. Other then this the engine runs great with no oil usage. Any ideas or suggestions? thanks Jeff
  3. I spoke with the company that I bought the turbo from and they recommend that I check the turbo bypass valve or the vacuum supply to it. Jeff
  4. I had a new turbo installed on my 2012 edge. It was an aftermarket turbo that was brand new. I noticed that after letting off on throttle I am getting quite a bit of turbo flutter noise. I’ve just dealt with it but it is getting on my nerves and I would like to fix it. Im guessing is a waste gate issue. Is the waste gate opened by engine vacuum? Any suggestions as to what to do to fix the issue. I paid to have it installed and rather not pay $120 an hour if it is something simple I can fix my self. thanks Jeff
  5. When I first bought my used 2012 edge I think it had the backup lines showing your intended path while backing. It quit years ago and I have not been able to figure out why they are not there. Any suggestions? thanks Jeff
