yazan
Everything posted by yazan
  1. there is power at the control module soket hot 12v and good ground how to test if its the signal not comanding the fan to run ? is it bad module ?
  2. still oem . didnt change it before
  3. Hello everyone please I need any advice. The fans stop working and got p0480 code. The forscan windows app will not start the fans at the test point Direct power to both fans will make them work
  4. maybe does it need case / crank / cam relearn ? or similar issue?
  5. when disconnecting the fuel feed to inkectors ,,, the fuel is shutting down after 3 seconds from cranking
  6. i think the problem is related to code u0100 U0100 Symptoms: Ford Edge Crank but no start, or no start and no crank.
  7. no , anti-theft / security /pats is not flashing or blinking oil change is ok today i got this codes with torque app b211b c1279 c1281 c1517 c2769 p1000 u0100 u0102 u0121 u0151 u2472
  8. i belive fuel pump is ok , i disconnect the hose socket thats feed the fuel injectors , and yes there is a strong line of fuel going to ingectors rail what else ? thanks for any help
  9. hi , suddenly the engine is cranking but wont start , no codes ! any help is deeply appreciated
  10. hi , please any help my wife edge 2009 got this codes p0010 p0020 p0102 p0340 p0344 p0443 p0135 p0141 p0155 p0161 p1000 are the related to each other ? any help is deeply appreciated
