Ford2504x4
Everything posted by Ford2504x4
Hi, So I have read the threads on this issue, and did the following testing. 1, tested the main switch, all working with the meter. both sides of all switches work up/down etc . Window lock switch included Power mirror, door locks work 2, checked the following fuses on drivers fuse panel , 1, 3, 15, and the big silver fuse, all are good I think 3, check for continuity of the blue wire from the harness drivers door to the window switch blue , it is good, 4 checked blue wire continuity though the plug, pin to pin is good, no broken wire . 5, applied 12v pwr to the blue wire door side, and windows work as they should. 6, no pwr from the car side from the blue wire. <---!!!! This is the issue I am chasing , and the harness does have pwr from other wires . 7.checked under the hood pwr box ,all fuses good. Rinse and repeated all steps 3 times , still nothing . TopDon code reader shows nothing although I am may not be looking in the right place on the scan tool Watched a few video's and did some searching but found nothing on where to check for. And ideas ?
Just a minor update, the brakes work fine now, I loosed the master cylinder nuts up about 10mm which fixed the issue, it seems the booster push rod is too long. so I am going to see if I find find the specs for the length of the rod, the Edge has been daliy driven with no issues. Merry Christmas all.
Bad news, needed new tires on the car , so got a appointment and on the way , guess what ? Yeah the front brakes started dragging again ?. They are hot and over heated . Really at my wit's end on this. If someone knows of a good Ford mech , let me know . I am going to try to loosen the master cylinder nuts to the booster and see what happens, after that remove the vacuum line to the new booster and see what happens, although if it was the booster all 4 brakes should be hanging up I would think...
Okay , I am glad to finally be able to say this, IT IS FIXED! Good solid brakes. ABS does what it is suppose to. The swapping of the mechanical's of abs unit did work.Thanks for that suggestion, that saved bunch of programing stuff of the VIN etc I put on the 3rd new master cylinder (OEM) and it bleed out properly . . Just a note , when I took off the brake lines to the 2nd new (Dorman Brand) master cylinder , fluid just flowed out of it, so the seals must have been toast from when the shop had it, why they could not see that leaves me questioning their skills , Rotors were with in specs . Yeah I threw a bunch of parts at it , well not really cause I have habit doing calipers, rubber lines, etc every 100k anyways. just never run into a ABS unit issue before. I am guessing the built in proportioning valve for the front brakes in the abs unit was stuck .. I hope all this helps the next person . Thanks to those that commented. ?
@Cerberus Well this was at the primary line (rear)going to the master cylinder that it squired , not at the caliper . The tech said the rotors were within spec , but I will double check for myself to make sure I have a proper gap. The calipers seem to have movement at rest . The new OEM master cylinder showed up to today so I will install it either tomorrow or Sunday . I know it appears I am throwing parts at it but they were aftermarket stuff and not OEM and the quality of after market replacement parts now a days can be very questionable. I just did my 2013 F250 pads and they were not the best fit compared to a couple of years ago, the gold level brake pads would not snap in easily .
Thanks DistractedDev, So this journey continues. Got a ABS unit, sent it to the shop , mind you it had brakes when I drove it just the front start to lock up as I drive it , they swapped the ABS unit , and could not get it to program or activate or do the PIN swap . I told them to swap the electronics, but they were going to charge me again the full rate, Not happening, told them to tow it back to my place, It has no brake pressure at all now . So I did the Electronics swap myself , No codes so far . Went through the whole bleeding procedures , even used a vacuum bleeder , I get a very tiny amount of fluid through the bleeders but no brake pressure build up , hmmm I am guessing the master cylinder is toast (Dormen brand). So I am going to order a brand new Motorcraft master cylinder and rinse and repeat of this whole saga . This is getting very old .... I am glad I have my F250 to drive as well as a Allante . But gas is not cheap and really want my Edge back on the road. I am open to any ideas even ones that suggest to just start drinking.
I suspect that is the issue. I did buy a used one so I hope that it works. Just hope the shop can swap the PIN # so the computer recognizes it.
Got a question, could the rotors be toast from hard braking actions when all this started with a bad booster ? what I am getting at is that they are over expanding when heated up ? I am using the WAG theory (wild ass guess) here Yes I know about warp-age and hot spots .
First off I am not trolling or F'ing with you, go search my user name on FTE under F2504x4 you will know I shoot straight period . I have been a gearhead for to many years. This one has me stumped , I even just replaced the primary brake line from the master cylinder to the ABS unit in case the short flex hose was bad. I have googled my ass off looking for a slimier case like what I am dealing with . Cracking the line at the master is where I got strange result of fluid being push out, it should not be holding any pressure . I could hear the front calipers releasing. Go drive it after several braking actions , calipers are grabbing again. I then cracked the bleed no gush of fluid. So yea it makes no sense. I did buy a used ABS unit as the next step , Yes i am aware of copying the number from the old ABS to the new one the computer will recognize it.
Bump does anyone have any info to offer ?
Took it for a drive and it started to keep the front brakes on after few stop and goes. Verified the rear (primary ) brake line from the ABS to the master cylinder is good , I cracked it open at the abs and it was holding pressure, fluid came out quickly which it should not being doing , I could hear the brake calipers releasing as soon as I cracked it. So I guess it is abs unit replacement time unless someone has any Ideas ?
Just more info, so I loosed up the master cylinder just to be sure the booster adj rod was not the issue , no change. pulled the ABS relay , no change after short drive , got abs light code but they self cleared with a short drive. both Master cylinders on the bench works like it should . Cracked open the back line from the master cylinder at the ABS unit , no change, cracked open both front calipers no change. thinkin about getting another set on front calipers and changing even though they are new.
Thx Ceberusr Yes i know that throwing parts at it is not the way to go, but I was dealing with different issues, the booster was bad,. Okay heres the latest and greatest update, I did replace the master cylinder incase I got a bad one, the adjustment rod on the booster should be correct , so drove the car after a full bleed . hmm good brakes , I then hit some gravel to do a full lock up. ABS kicked in worked as it should . but afterwards the front brakes started hanging . So I got the front wheels off the ground , put it in neutral and they will not spin freely. Put it on drive , same thing they will not rotate properly. So i then cracked the front brake master cylinder line, no change, then when I cracked the rear line, the front wheel spun freely . Can the braided line going to the ABS unit go bad ? I ask this because pat of it is steel then braided then goes back into steel before going into the ABS unit. yup screw the grammer police ? Thx for helping out .
So here is a list that has been done, 1. New brake booster and new vacuum booster line and valve which did fix the low pedal, no brake light, booster rod is adjusted correctly 2. Now i have front brakes that are hanging up. 3 I have replaced the master cylinder , 4 all calipers and rubber lines along with pads . 5. abs light is not on but does show when starting . Abs does function correctly when you stop hard all 4 corners . 6 I still have a front brake dragging issue. Verified by lifting the front wheels off the ground and they will not spin freely in neutral . Note When I redid the master cylinder, when I cracked both lines going into the master cylinder, there was fluid that squirted out under a little bit of pressure, this seemed odd, since usually just drips. So maybe it is abs ? is the propitiating valve built in to the ABS ? Do you have reprogram the ABS when you replace it. ?
Hi everyone, I have 2011 Edge Limit 3.5 , got it with 70k now has 230k , great car, some here may know me as F2504x4 on FTE (fordtrucks.com) and i am coming here to keep from pulling what little hair i have left out on a brake issue. i have made post in the section for 2011 Edges. thanks for any help on this. I am a Vet and race go karts in Ohio
Hi everyone, looking for help on this, some of you may know me on FTE as F2504x4, so i have been around Fords for a very longtime , but this brake issue has me stumped. I have 2011 3.5 Limited 2wd with 200k. the issue started with the booster going bad, and I now have the brakes hanging up issue on all 4 corners and not fully releasing, I have probably toasted the rotors now , so here is a list of what I have replaced so far . I started with a new booster which fixed the soft pedal issue. Brakes still were not right so I replaced master cylinder twice thinking i got a bad unit, still no change, so i went and did all the calipers with brackets front and rear along new rubber lines , new pads . Brake felt great as to stopping , good solid pedal but now the they do not release fully, you can feel the heat coming off all 4 corners after driving it long and short distances No ABS light, have tested it by hitting the breaks hard forward and reverse, system works like it should , all metal lines are solid . The pedal is firm , and braking it good. What am I missing ? I have googled this and have not found a answer, any ideas I should explore ? I am at wits end here. BTW the fuel mileage has dropped down to 15 mpg when I use to get 22 plus .
