gjscott4
About gjscott4
gjscott4's Achievements
  1. Sooooo... I bought a 2013 Ford Edge with a bad BCM. I replaced it with the exact same part number, programmed it to factory specs with download from FORD with FORSCAN. It cleaned up all the issues I was having prior (Door locks locking and unlocking, hazards flashing, numerous dash lights, etc.) - except for LEFT Rear Rear Door Ajar... Deleted old Keys, reprogrammed two new keys with FORSCAN. They work, unlock/lock the doors, start car. Keypad works, locks/unlocks doors. Door switch to lock/unlock on both driver/pass doors only unlock the door (BUT! only when you click the LOCK button. I took one switch and put it on other door and it did the same thing. Not sure what the logic issue is with that. The Left Rear Door Ajar light is illuminated (was before BCM changeout) and I can not get it to go out. Even when I try and short the green wire going to the sensor. I have changed the entire assembly for the sensor/latch with a new part. I am not sure if this falls under a programming error on the PATS or if there is something more diabolical going on. I can live with it the way it is honestly, but the issues of lights coming on and keypad illuminating is causing a battery draw and killing it. Car runs amazing though. Any ideas? Ford wants a $135 an hour to stare at it like me.
