openrage
Everything posted by openrage
  1. Ok battery tests good. I cleared the codes with no change to how it is acting. Codes below B1214 B0021 B0029 U0155 B1193 B124D U0140 B11E5 This is a former wreck so I assume the airbag ones are probably them missing
  2. Thanks for the info I will be able to pull codes tomorrow when USB dongle shows up for forscan and have the new battery load tested. I did check fuse 11 and has 12.7v ignition on, 14v+ engine running. I checked the Blue/Red wire at IPC and have 12.7v, ground tests good continuity to steering column. I did leave battery disconnected for a few hours, tried BMS reset but with no cluster I dont know if it did anything, also let it sit a few days untouched and off for the 8 hour reset. Ill post what forscan shows once I can hook that up. Glad I am at least looking down the right path will know more when im back in town.
  3. Picked up a 2012 Ford Edge Limited and have a weird issue. The Instrument Cluster does not power up, no lights, no speedo, no screens. The Radio will power up then immediately System Off to Save Battery. Climate controls are stuck on heat defrost so I assume those buttons are just soft buttons for the radio controls. I have replaced the battery it was weak, alternator tests fine. Since there are multiple systems affected I assume there may be a common component that may be causing it all. Any thoughts?
