JMB
About JMB
JMB's Achievements
  1. My apologies for taking so long to respond back to you. I knew something did not see right with torque values. I guess that is what I get for buying a manual off eBay. Should have come here first. I was able to get the brakes done. I was amazed how easy it was to push the pistons back into the caliper. I do not need to spin them back in. I bought a brake tool compressor kit believing I need to screw them in. Will also use the info here to do the front. Thank you very much Haz for posting this for me.
  2. Good morning everyone. I am do the rear brakes on a 2017 Sport. I was looking for the torque value for the caliper bracket and the caliper slide pin. I purchased a down loadable Ford repair manual 2015 to 2024 manual from eBay. Manual is date 2015. That has the caliper bracket at 99 ft-lb and the slide pins at 21 ft-lb. I thought to myself 99 ft-lb seemed high. I started to look around on line which seems to be hard to find exactly. Goggle has it at 66 ft-lb. Also a YouTube video on a 2018 Sport has it at 41 ft-lb. Caliper side pin I have found at 21 ft-lb and 19 ft-lb which is not to far off. Wheel torque is right at 162 ft-lb which is correct.
