Beyondonedge
About Beyondonedge
Beyondonedge's Achievements
  1. I had a bizarre (or maybe not so much) encounter with the issue today. I was driving and had the a/c temperature set to 25 degress Celsius. As the inside of the car began to get quite warm the issue presented itself with the same exact symptoms mid drive. When I got to my destination I had to unload everything by lowering the back seats as the tailgate would not open (which was fun). The car was left for about 20 minutes. When I returned and started the car again the a/c turned on straight away. I am thinking like you guys mentioned maybe start by replacing the FCIM. Do you think it is best getting a used one or see if I can get it new from Ford?
  2. Thank you both for your suggestions and advice. I'll keep looking and update if I find anything.
  3. Hi. So I did all the tests I could. I started off with another CCA test, then Cranking test, Charging system test, Ripple test. At the end I did another CCA test and noticed it said 661 from 636 at the beginning. Not sure if that is good or not. Would a few minutes of engine running make such a difference?
  4. Thank you for your reply. The tester does indeed offer a few other tests so I will do them all and provide an update.
  5. Hi. I finally got round to testing the battery with the tester you recommended. I have a photo of the result. I guess this means it is good? Any further ideas? Now that there is no hot weather there is no way to recreate the conditions to check if any solutions work; which is annoying.
  6. Thank you for your reply. I just ordered myself one which will arrive end of next week. Is using this device self explanatory?
  7. Well, checked all connections both on BCM and the power distribution box in the engine compartment. No signs of corrossion, sprayed them with contact cleaner anyway. Still not working. Starting to regret buying this car. Any ideas?
  8. I also forgot to mention, I also noticed when the symtpoms appear, the park assist system will not work, I get the malfunction error. I do not use it hence why I did not notice it before but I got curious yesterday. If everything else works, the park assist seems to work too.
  9. Update: This morning it happened again. Interestingly, I drove with the windows down (I had to, too hot) and it sorted itself mid-drive. However, I go back to the car after work and it has been like that since. I had a bit of time so took it to halfords to check the battery but they said it was good (see photo). I guess next step try replacing FCIM?
  10. Once again this morning it is back to normal (a bit cooler today). I am really puzzled by this.
  11. Just an update at this point. The issue has occurred again today. Normally once the vehicle cools the issue goes. But not today. I have tried clearing DTCs as well which has not worked. I have not had a chance to check the battery yet. What is the best way to check it would you say? Or is it worth replacing the FCIM? I have attached my DTC log; if anyone can help point me in the right direction I would really appreciate it. DTCs symptoms present 12aug2025.txt
  12. Hi, Just joined trying to see if I can find a solution. I apologise if there is a post with a solution somewhere. I have a ford edge 2017 which I bought used back in November 2024. Not every single time but on several occassions when the weather is hot I get the following symptoms: • No AC, options grey on touchscreen • FCIM appears completely dead, no buttons will work BUT radio if already on from before can be controlled from steering wheel • No external temperature displayed on touchscreen or IPC. Instead it reads "--" •Airbag icon/light on the dash •Electric tailgate will not open After reading post on forums both about the ford edge and other models I thought maybe the FCIM may need replacing. When I disconnect it I can recreate all the symptoms except from the tailgate which works fine. This leads me to think it may be a connection issue somewhere which the heat triggers? Frustratingly, it is always when I really need to use the AC and instead have to stick to keeping the windows down on the motorway. Has anybody come across this and found a solution? I want to avoid the bill from the local ford dealer if I can. Can anyone direct me to the connections involved and their location so I can check them? If it is of any use the part number of my FCIM is HM2T-18E245-ARA Thank you
