Jared Isham
About Jared Isham
Jared Isham's Achievements
  1. I actually found it at O'Rielly's https://www.oreillyauto.com/detail/c/standard-ignition/lighting---electrical/connectors---terminals/parking-aid-sensor-connector/f150988703f7/standard-ignition-3-terminal-parking-assist-sensor-connector/std0/s2393/v/a/92778/automotive-suv-2010-ford-edge?q=parking+aid+sensor+connector Hoping to install it soon, but also need to find the bracket that holds the sensor in place on the bumper.
  2. What about something like this for the sensor plug. I am kinda curious to know if I can just splice these wires to where the original sensor was cut and then attach a replacement sensor. $30 is much nicer than $150 https://denalielectronics.com/products/dnl-whs-050
  3. I have a 2010 Ford Edge SEL that was rear-ended in the passenger side corner. Being in California they decided to drastically increase the Salvage title restrictions, so in order to get it to pass the VSSI inspection I need to have my bumper replaced or at least assembled without the cracks and with the sensor working. I pulled the bumper off and found that the far left (passenger side) backup assist sensor is completely severed from the wiring harness - not sure if that was the collision company that did that or if that was due to the fender bender. Anyway I either need to figure out how to wire in a new sensor or replace the entire sensor assembly cluster. (Part # 7T4T 14N139 G2816) Does anyone know where I can find that part, hopefully not $300. Or any suggestions on where to get the connector so I can splice in new wire to make the cluster work? Attached is a picture of the part tag, the severed line, and what the assembled sensor looks like
