Meg
About Meg
Meg's Achievements
  1. Oh that is bad news for us! He is currently replacing the valve covers. No catch can. The seal is OEM, part number FL3Z 6710B. It won't let me post a link a link to the exact oil pan he installed in December, which was off of eBay from Tom Auto Parts. I am going to try and attach the photos of it instead. It lists the following part numbers: FT4Z-6675-A,FT4Z-6675-B,FT4Z-6675-C,FT4E-6675-DB so most likely no check valve and he shouldn't have installed the gasket. Hopefully no engine damage has occurred. Needless to say he is pretty discouraged and regretting the aftermarket purchase. At this point would we be best off to purchase another OEM pan, or reinstall the aftermarket pan without the gasket? He can hardly wait to get started 😢
  2. If we replaced oil pan with part number FT4Z6675D but neglected to do valve covers as referenced in the TSB could that cause the car to start smoking intermittently? My parents have a 2017 Continental with the 2.7 turbo. It has seen meticulous maintenance from them with no issues other than the terrible oil pan leak. In December my husband replaced the oil pan with an aluminum pan purchased on eBay and the OEM gasket. It's an aluminum pan part number FT4Z6675D. A week later they drove 1500 miles to Texas. On the trip my elderly dad thought the engine sounded noisy. He stopped and checked the oil and it wasn’t showing on the stick. He added oil and said it quieted down. He then began checking it and saying it was reading low about every time they fueled up so he was adding more oil. We went to visit them and my husband replaced the PCV valve, looked for leaks, put ats205 in it. Since returning home the car developed intermittent smoking issue. Husband then replaced left side turbo since it seemed to smoke more on that side. Smoke cleared up for about 3 weeks. Car then started smoking again. Another shop checked and says oil (my dad had added again) when car is first started oil reads low and then after an hour reads over full. Their hypothesis is worn valve guides or heads. Car runs great, sometimes smokes, sometimes doesn’t. Brian is wondering if this pan could be causing drain back issues. (Missing or covered passageways?) He did NOT replace valve covers as is referenced in the TSB posted earlier in this thread by @Haz. Could that be contributing? Hoping to get some insight. Have you run into anything like this? We are happy to pay you for consult. Your content has been hugely helpful to him in the past. Thanks for time! Megan
