sheshe24
Everything posted by sheshe24
  1. just fyi. dealing with same problem. purchased part # 9E514000AC. i have a 2013 ford edge sport awd manufactured 10/13/2013. OE/OEM Part Number 9E514000AB, 9E514000AC, ZZD027100, ZZD027100A DOES NOT FIT ford edge manufactured AFTER 07/29/12. i don't care what dealerships say, what ebay says, or anyone else. it absolutely will not work.(if u do happen to purchase one on ebay and use the guaranteed fit and it doesn't, ebay covers return costs.) you need: OE/OEM Part Number S-154-A DT4W-4000-AB fits anything manufactured AFTER 7/30/12 2013 Ford Edge Limited Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge Limited Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SEL Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SEL Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SE Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SE Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge Sport Sport Utility 4-Door 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Lincoln MKX Base Sport Utility 4-Door 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 MKX Rear Axle, from 07/30/12
  2. seems to be quite a common problem. i have a 2013 ford edge sport 134000 mi on it, manufacture date is 10/13. the dealership just told me the rear diff is going out. so I'm searching everywhere for one online, all the genuine oem ford websites says its backordered but seem to agree on the part # 9E5140000AC. in a lot of the searches it says through 7-29-12. so that's where the confusion for me is coming in, since it was manufactured after that date. do they mean current date backwards to 7-29-12?
