31bullitt16
Everything posted by 31bullitt16
  1. Can the 3 non auto windows be converted to auto up/down on a ‘14? Is it just a matter of swapping out the switches?
  2. There’s only 6 attaching points for the struts. Have you checked the Inner tie rods, rack mounting bolts/bushings?
  3. Other yr posts will have the yr they were posted. Do a search here for how to install, also forscan has a forum and other ford forums that go into using forscan along with u tube. The antenna mounts behind the lr trim panel and is attached to the tpms with the cable, it’s attached to the car with cable ties. I would check to see if the antenna is already installed. There’s a place for the hood switch and a pig tail to hook it up that’s already there, it’s on the pass. side next to the headlight. That’s about it other than forscan.
  4. Thx for the replies. I looked at some aftermarket kits but too many seem to cause codes to pop up or some random issues that get fixed when the RS kit is removed. I'd like to stick with a factory RS to avoid any issues. While doing some more research a link to a post on here from 2013 showed up, one I didn't see before. From that post: "it appears that 2013 Edges with power liftgate have everything except the key fobs and programming already installed in the vehicle from the factory. The kit DA8Z-19G364-A consists of nothing but two key fobs. On the other hand, models without the power liftgate apparently don't have the requisite additional equipment and so require the BC3Z-19G364-A kit which includes the antenna, coax cable and two key fobs." The post had a link to a PDF that listed what was needed for what yr unfortunately it's DOA. It looks like the liftgate needs a 5 button remote, the 5th for the RS and no liftgate needs a 4 button. Also in that thread the OP had a '12 that required the antenna for it to work and his did have the power liftgate. At some point Ford changed how they were built apparently, from TPMS to OBD. Mine should be TPMS based on build date. With that I decide to get 2 new 5 button CCP keys for $25 and a hood switch for $28 from Ford all off of feebay and see if I get lucky and don't need the antenna. If I do they can be had for $30-50 from a dealer. Next question, the IDS module programming, can that be done with Forscan?
  5. 1st thx for the add. We recently picked up a nice ‘13 SEL that I would like to add rs to. I’ve looked thru some older post about doing this unfortunately the various links mentioned are old and doa plus they tend to be a hodgepodge of info that aren’t specific to our Edge, like power liftgate, but I could have missed it too. One of the posters mentioned all the parts are already there on a ‘13, there wasn’t a confirmation if that’s true or not in any replies, is it true? If so, what’s needed besides enabling rs in Forscan? If not, what are the options to add rs with power liftgate and what parts are needed? TIA!
