baumgardner1
About baumgardner1
baumgardner1's Achievements
  1. i did check all the fuses and everyone of them is good. the high beams work also. i contacted ford service tech and he told me to check the plug itself because they tend to get hot and melt the wire inside. he also said if that wasnt it then the junktion box is bad (aka fuse box). this is the 2nd time this i had this problem and they replaced it once already and yes the truck is still under warrenty...i knew i got 100,000 mile warrenty for a reason. so i am going to check that and i will let you all know what happens with that . thanks
  2. i have a 2007 edge sel. the left head lamp stop working.....all the fuses are good , i tryed a new bulb and checked the plug with a test light. there is no power at all and there is a ground. everything is there but the power. the fog lights work and the right headlight works. please help thanks
