Everything posted by v8vega
Sync 3.4 20282 Update No Sirius Album Art
v8vega replied to SMR2818's topic in Audio, Backup, Navigation & SYNC
Did you do a full system reset? -
Front Camera issue - 2018 Sport
v8vega replied to v8vega's topic in Audio, Backup, Navigation & SYNC
The dealer ended up having to replace the front wire harness. Just picked up the car tonight and all is finally working as it should. The screen finally shows the small vehicle symbol in the top left too, It hadn't shown that before. Both 180 degree and split view work great. Honestly don't know if its a feature I'd use alot, but nonetheless it should work if you pay for it. lol -
Thanks I'll follow up and send the service tech an email on this too. -
Got the car back from the dealer after they replaced the front camera. The split view still doesn’t work and when I got home the camera stopped working again. I now get a message that says “camera is unavailable”. The next morning it worked again on wide view, but not on split view. Anyone have any ideas? The dealer is working with Ford to find out whats going on. They don’t understand why split view isn’t working. I wonder if there’s a connection issue somewhere? -
Panoramic Vista Roof Re&Re
v8vega replied to v8vega's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks omar302!! That's exactly what I was hoping for. -
I just purchased a 2018 Edge sport that has a cracked front vista roof glass. (the slider). I got a deal on a replacement unit from a wrecker off of a 2020 Edge that just came in. I do see the 2007-2014 video where it shows only 3 bolts on each side of the unit to remove it. I don't see any video or instructions online for the 2015 to 2020 anywhere. Question I have is has anyone replaced the unit on their own without taking it to a glass shop or dealer? Any info would be much appreciated. Thanks
Update: Over the weekend the front camera wasn't working at all as shown. Monday morning on the way to the Ford dealer the camera began to work only in 180 view, but not in split view. Dealer called me today and said the camera is no good and will be replaced. -
Last week my front camera stopped working on split view, but worked fine on the wide angle. Today the screen is black momentarily and then turns blue. Anyone come across this before and any ideas on what I could do to check/fix this?
UPDATE: After the 3rd visit to the glass shop (on behalf of the dealer) the windshield is finally sealed. Wind noise inside is no more.
Thanks for all your inputs. I will take it back to the Dealer to have it checked. I noticed the cowl below the hood and under the windshield is also not supported in the centre and it sags a bit, so the wind could be hitting the lower part of the glass. I stopped by another dealer to see if this was normal on other Edge vehicles and those ones were supported and didn't move when I try to move it up or down.
The windshield was replaced just before I took it out for an initial test drive. I have a few Fords, including an older Edge Sport. This noise is definately not the normal road, wind, highway noise. I also took a 2019 and 2020 ST and Titanium for a drive and they don't have this issue either. I'll take it to the dealer where I bought it from to recheck the windshield install and trim placement. Drivers side trim doesn't feel the same as the passenger when checking it. Found this Ford TSB for the 2016 Lincoln. (TSB 16-0088) It talks about a "stuffer" which goes under the moulding to most likely keep the wind out? If you have these can you take a pic . Thanks.
Last week I purchased a 2018 Sport with only 15000 km's (9300 miles). I've been driving it for the past three days and when I reach 40 mph and up there is excessive wind noise coming from the front drivers side. The dealer had replaced a cracked windshield and I believe its coming from the windshield trim. I can't push down the passenger trim, but the drivers can be moved slightly down when I press on it. Anyone hear of this issue or similar before?
2010 Edge Autostart
v8vega replied to luckybiggs's topic in Alarms, Keyless Entry, Locks & Remote Start
I've got a 2010 Edge sport that i'm looking at installing a ford car starter into as well. Did you get any further instructions to complete you instrall? If so, could you pass along. thanks -
I have a 2010 Sport that doesn't have a rear power tailgate. I'm thinking of buying a unit from the wrecker and install it in mine. If anyone has experience installing one of these, or some tips I would appreciate your input.
I just bought a 2010 Sport AWD with 22 inch rims and scorpion tires a few weeks ago. We've had a winter storm with almost 40cm of snow, over a 3 day period, and I got around with no problems. I expected I'd have to buy snow tires, but not any more. They're really good!
So I guess its basically the rapid 400A code.
That's what I thought too. I've attached a portion of the window sticker showing the options and base 215A if anyone has any comments on this.
Just wanted to say hi and wish everyone a happy new year!
Before purchasing my 2010 Edge Sport this past week, I took an SEL out for a test drive. It had low mileage on it and during the test drive I experienced a squeak coming from the inside of the vehicle. It took me a few moments to realize it was coming from the drivers seat. When driving slow I turned the steering wheel side to side and sure enough the squeak was there each time. Maybe the same issue here?
From the album: My 2010 Edge Sport
© © 2007-2008 FordEdgeForum.com
