dc331903
Everything posted by dc331903
  1. Too easy Norm . Really, I wanted a clean look that would run a black, iPhone cable under the MFT and to my phone. Since I have an iPhone 6, I really wanted to use the 2.1A as it actually loses battery when plugged in and the screen is running an app like Waze throughout my trip. Could certainly pull that off with an adapter, you are correct. I was making it harder on myself, but wanted more of a built in look. Who uses those things for much else than USB anyways?
  2. Ignore - found it. Fuse 27 - front power point/lighter
  3. To add, all other ports are showing 12V on the multimeter but this one shows nothing. I tested all the good fuses but not compartment fuses yet.
  4. 2011 Edge Sport. Pulled my useless 12V socket and am replacing it with a dual USB port socket. This simple mod has a hiccup and I am pulling my hair out. Where is the fuse for this "power point"? It is on the passenger side below and to the left of the glove compartment. Manual has fuse listings for 3 power points (console rear, inside console, and cargo area) but this is no where to be found! Ideas?
  5. I get the same error. 2011 Ford Edge Sport. Took it in under warranty and they removed and replaced all the sensors. That did not fix the issue. The sensors are fully functional except that there is no beeping when backing up. It is just an annoyance for me now and I'd be happy if I could just turn off the warning message. Let me know if you find anything.
  6. Reviving this old thread - anyone that has adjusted the projector (to stop blinding oncoming motorists) - any idea how much of an adjustment it took? 1/2 turn, 3 turns? Dylan
