lpgao
Everything posted by lpgao
Hi guys, Can anybody give me information on how to update map for my 2011 Edge? I found my one missing many streets.
Hi, guys, I am going to replace tires for my 2011 limited. I am wondering I should change them all or I can just replace front two? BTW, "good year" tire is good enough or what brand tire is better?
thanks for guys nice replies. I appreciate very much. I decide not to replace tires for now because tire just got a nail and it was repaired.
what I should know to replace my rear pair of tires? can I put wheels to front after I replace them with new tire?
winshield glass
lpgao replied to lpgao's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks for you guys kindly reply. I am very appreciated for your helpful information. -
I plan to replace my 2011 Edge limited winshield glass because it has crack or small hole. What I should know to do this?
airbag warning light stays on
lpgao replied to lpgao's topic in Alarms, Keyless Entry, Locks & Remote Start
Thanks lot for your kind reply. I will take serious consideration for your suggestion. My last concern to replace battery is after disconnect power the software for my ford touch will be lost or maintained in system? or say replace battery will not affect any function of Edge? -
Thanks for your guys great replies. But I think I need make things clear what is going on with my Edge. My edge is complete working as normal now. No warning light at all, and everything is functioning. I checked battery again with a battery tester, and it shows battery is in good shape. I did not touch #37 fuse again because I am not sure what is going to happen. But I think the battery was drain out yesterday for some unknown reason. One question here: if battery dead my edge will maintain all software? and no program will lost? Edge will working normal once new battery in? -
Thanks akirby. I want share my situation here for everybody. As airbag light was still on and climate control not working as well. I did several things. First, I moved diver and passenger seats as suggested wires may be pressed. It did not fix problem. Secondly, I pulled out fuse #37, which is for climate control because I want know if whether it is good or not. I found fuse is good. I put it back. Sony systems back to normal and airbag light not there. Third, I pushed start engine button. I heard very little sound and engine did not start. I saw many warning lights on dashboard(LCD). I tried to start engine a few times more,no luck. Then no screen on any more. remote could not lock door. everything dead. I could not move gear to neutral for tow truck. Fourth, when tow truck here, his boost connected my battery, everything come on, door lock working, started engine,no warning light,climate control working normal. He suggested to replace battery, which is OEM. Fifth, Battery service guy coming, he tested my battery is good, 545 A cranking,12.5 V. Stated engine, 14.5 V. So he said no need to change battery, and alternator working fine. So why? what went wrong when I pulled out #37 fuse? and this indeed fixed climate control. How battery was dead and it was tested good? -
My 2011 limited showing airbag light solid on, no flash. Same time everything on sony dual zone climate control not working, including climate control, power on/off and volume for radio, hazard light button. What wrong? how to fix?
I had it for more than one year and I drive it all the time. It shows me Sony dual zone climate control not working, nothing else. -
Thanks for your post. This is 2011 model. It was sit in dealer for 6 months before somebody bought it. Then it was in dealer for another 6 months until I got it in 2013. So I think battery should be ok. I am just wondering why nothing working on Sony panel? those including climate control, volume and hazard light button. -
Thanks for your post. If I pull out fuse it will affect software installed and I lost all control? -
my airbag warning light stays on, then I found climate control system not working, plus "hazard" button not working, or everything on sony control system not working. anybody has idea what is wrong and how to fix?
I am not sure if I should post here or somewhere else because I could not find right section for this. My sony dual zone climate control panel not working, the button for emergency not working as well, plus I can not do anything on climate control on my Ford touch. Everything else working well. I saw a airbag warning light on, if it is problem? How can I fix it?
sun roof closing problem
It is strange thing. I wanted to try this method but I can not believe I closed window. Last time I could not close it when I tried several times in different days. I dony know why this happen. Window closed so I did not go through initialization process. I will see what happen again. -
Sunroof Initialization
lpgao replied to eifel's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Thanks Youri631 for your kind replies.I will post my result when I done on my car. It was done by somebody a month ago. He did it by accidentally because he did not know what exact to do but got roof closed. Then yesterday I could not close it again. I did not do anything yet until I get information here. With my roof not close fully how can I do step 2? -
Thanks for your kind answer. I will post my result when I done on my car. It was done by somebody a month ago. He did it by accidentally because he did not know what exact to do but got roof closed. Then yesterday I could not close it again. I did not do anything yet until I get information here. -
Do you think step 2, 3 are conflict with step 5? what means to hold down switch during whole process? then ask to hold down and release in step 2 and 3? -
You said to hold down close button, but before your posting, it said held down opening button, so closing or opening? or I understood you mean just hold down switch wait for fully open, and fully close again, there no release button in step 2 and 3? Just one step: held down button or switch? -
another question is what is 2011 ford edge manual? owner manual? or something else? where I can get it? -
Thanks for guys kind of replies. Here are what I got confused:in step 2,3,4,state to release button or switch, but in step 5, saying to hold control witch, what control switch is? -
Thanks for your reply. The link you put here I read already. There are a few confusions regarding re-initialization steps, for example, it said to press switch during whole process, but in each step it says "press and release", so what I should do? hold or press/release? what "press"means? because to close window you should "pull down" switch, and to open you do "press up", I think English is not very good in that description. not clear.
