misterfixit
Everything posted by misterfixit
I don't have any pictures. To see the metal that is too short I would have to pull the weather strip out. It is glued in with yellow rubber adhesive. "All you need to work on a ford is a hammer, oil can, duct tape, bailing wire and gorilla glue."
Talk about poor quality and customer service on this forum gets your posts edited and thread closed. I found out I just have to live with the problem on my vehicle but I probably will not buy another Ford.
For those complaining about Ford Customer Service
misterfixit replied to bce's topic in Dealership & Vendor Experiences
What does this have to do with complaints about Ford customer service? The complaints with Ford vehicles and customer service are still there and this doesn't invalidate them. -
Quality(or lack thereof) and Customer Service Impressions
misterfixit replied to misterfixit's topic in Owner Impressions
So anybody's opinion that you don't agree with you just edit it out and say that they are "silly" and are "inadequately whining". You don't know if it is properly fixed or not. You haven't even been involved with the situation or even seen my vehicle. But you are entitled to your opinion and I'm entitled to mine. And you may be the moderator but you shouldn't have the right to say someone is "being silly" or that their opinion is "inadequate whining". There is more to this situation that you don't know about and I'm not willing to disclose it on here. But I will move along. -
I have been told that before but I haven't seen the actual manual or if it states that it is ok for weatherstrip that is designed to be pressed in is ok to be glued if the door is out of spec. I haven't asked you to help me further. And for the other two of you you seem to have to have the last word. So have it. This will be my last Ford. -
Wendell didn't give me access to the information I requested. He didn't answer my last email. He doesn't care about customer satisfaction. It doesn't matter if the weatherstrip seals. Glue is not a fix. It is a patch. It isn't permanent. The door is out of spec. -
How do you know it is fine? What gives you the right to speak for me? They patched it. Ford quality is lacking. Wendell will not answer my email. Another sign of poor customer service. -
It would if the metal channel was consistent but it isn't. -
A hammer, oil can, bailing wire, duct tape, and gorilla glue. That's all you need to "fix" a Ford. Out of spec is out of spec no matter how you look at it. Glueing it will not provide a more consistent seal. There are things you can do to please "some people". -
No. -
It is glued. It wasn't designed to be glued. There was not enough metal on the fold on the door to hold the weather strip in place. I don't consider it an upgrade. It is just a band-aid fix. -
My opinion is Ford customer service doesn't care about complete customer satisfaction. -
The last Ford that I owned before the Edge was a 96 tbird. It leaked around the rear window and the rear window trim didn't fit correctly because the clip studs were spot welded in the wrong places. The ac drain was stopped up due to a kink in the drain and soaked the padding in the front passenger side. The service department unkinked the drain but left the padding soaking wet. It also had transmission problems. The service manager stated that the transmission fluid was "tired". I thought I would give Ford another try with the Edge. I wonder what will be next. -
What good would it do to carry it back to the dealer or another dealer? Mr. Barron has the final word. I still haven't seen a copy of the so called "repair guidelines". Ford doesn't care about customer satisfaction. I will remember that fact. -
I still haven't seen these so called "guidelines". -
So the CSM states that the adhesive is acceptable. Maybe it is approved and acceptable for weather stripping that requires adhesive but I'm still not convinced it is appropriate for weather stripping that is designed to be pressed into place. The door on my Edge is out of the spec tolerances. I'm convinced that Ford customer service is just trying to give me the brush off. -
I'm still hanging. -
I have experienced quality issues on the front driver side door and weatherstrip. The weatherstrip and door were designed to go together in a groove without adhesive. The door on my vehicle is out of spec and the groove does not have enough metal to hold the weatherstrip in place. So the dealer decides to glue it in. Ford customer service states that it was repaired to their "guide lines". They will not show me these guide lines. What is next?
Still no answer.
I requested a copy of the guidelines from Wendell Barron via email. He is Jessica's supervisor as far as I know. He did not respond. I also told Jessica via email that I would like to see the guidelines. She didn't respond to that request either. Todd
Sorry - somehow I double posted.
He contacted me today via email. He stated it was repaired per ford's "repair guide lines". I would like to see a copy of these "repair guidelines". The service manager tried to tell me first that it was installed wrong then after he worked with it he tried to tell me it was ok the way it was. It fell out of the groove by itself the first time and would fall out of the groove by just barely touching it. The door fold for the weatherstrip is off spec. It was not designed to be glued in. The service manager did not mention any guidelines for repair. All he told me was that he would try some contact cement to see if it would work. Ford customer service doesn't seem to care about satisfying customers. Time to go to Ford's Facebook page.
I was contacted the next day and a voicemail was left on my phone. I had waited for a call but I can't stay by my phone all the time. I called back and left a message by voicemail. I was called back about 5 hours later and was left a voicemail. I called back and left a voicemail requesting to be contacted via email. Still no response. I suppose I will start posting about this on Facebook.
I have asked her to forward my requests to her supervisor. She agreed but I have not received a reply as to whether she has or not. I have not heard from her supervisor either.
I still haven't received a satisfactory response from Ford Customer Service.
