2014WhiteEdgeSport
About 2014WhiteEdgeSport
2014WhiteEdgeSport's Achievements
  1. Is there a difference between the front brake calipers/brackets on the 2014 Edge Sport AWD and the Limited/SEL AWD models? I am looking at the bracket/carrier to see if I buy a spare, if I can file the bracket slightly to get the clearance needed. Everything I am finding shows it will work on all except with 22" wheel... so are the Sport brakes different?
  2. I have done some searching and have seen the Explorer wheels rub, but this is the first I see the Taurus wheel rubs. RustyEdge... what size spacers did you need to usefor the Explorer wheels? If spacers are needed for both, I would definitely prefer the Explorer wheels as they are 8.5" as opposed to the Taurus wheel only being 8". They look identical in pictures...
  3. I know this is an old topic, but if they have an offset of 39mm; which is the same as the edge, why would they rub? The Explorer has a wheel that looks the same, and the offset is 44mm... thoughts?
