donaldy
Everything posted by donaldy
  1. Sounds like that is what is happening. Isn't there a drain at the front? Seems like that should have been obvious to the dealership if that is the case. Thanks for your input.
  2. My 2015 Edge has entered it’s first rainy season. When parked flat, or facing up hill it does not leak. However I back in to my 25 degree sloped driveway and water pours in the center of the roof at the location of the dome light switch/panoramic roof controllers. Fortunately I found it early and was able to put down a blanket to absorb the initial run off. The dealer had it for a week and took it completely apart and thought that the leak was near the rear of the roof and when facing downhill it ran to the roof center console area. Unfortunately the dealers efforts did not solve the problem as it still leaks under those circumstances. Anyone else had this issue? There are lots leaks reported, but few regarding the roof. The dealer suggested it was a 'sheet metal' problem and leaked into the roof area even if not parked downhill.
  3. 2015 Edge leak from upper center console by glasses holder My 2015 Edge has entered it’s first rainy season. When parked flat, or facing up hill it does not leak. However I back in to my 25 degree slopped driveway and water pours in the center of the roof at the location of the dome light switch/panoramic roof controllers. Fortunately I found it early and was able to put down a blanket to absorb the initial run off. The dealer had it for a week and took it completely apart and thought that the leak was near the rear of the roof and when facing downhill it ran to the roof center console area. Unfortunately the dealers efforts did not solve the problem as it still leaks under those circumstances. Anyone else had this issue? There are lots leaks reported, but few regarding the roof.
  4. 2015 Edge leak from upper center console by glasses holder My 2015 Edge has entered it’s first rainy season. When parked flat, or facing up hill it does not leak. However I back in to my 25 degree slopped driveway and water pours in the center of the roof at the location of the dome light switch/panoramic roof controllers. The dealer had it for a week and took it completely apart and thought that the leak was near the rear of the roof and when facing downhill it ran to the roof center console area. Fortunately I found it early and was able to put down a blanket to absorb the initial run off. Unfortunately the dealers efforts did not solve the problem as it still leaks under those circumstances. Anyone else had this issue? There are lots leaks reported, but few regarding the roof.
