Kennyp14
About Kennyp14
Kennyp14's Achievements
  1. Lenny, what year is your Edge? Mine is an '11, and I was not able to find the correct wire for the drivers side in the loom of wires under the sill plate. This makes sense to me since the latch is in the door, so why would the wire run from the door and then make a turn and run under the sill plate? I had to track down the correct wire WAY UP under the dash near the fuse panel. It took some serious patience and body contortions to get up there and tap the wire! Ultimately I should have probably just removed the door panel to get to the wire.
  2. I am kmp14. It appears I have 2 separate accounts on this forum, but only remember the password for this one (Kennyp14). Anyway, yes, it was REALLY HARD to get a tap on to that wire way up above the fuse panel. I think it took me an hour+ of contorting my body to finally get a working tap on there. Maybe the door panel approach you are considering might be easier. Let us know how it goes, and if you have the patience, take pictures as you go so it can a useful for other in the future! Good Luck!
