Well that didn't do it. Still not always coming on when it should. If I wiggle the pigtail a little at the fan they will come on. Does anybody know if I can get a replacement wiring harness for the 3.5 on a 2012 Edge? Thanks!
I unplugged the controller harness and top fan harness , shot some contact cleaner on connections and both fans are now working as they should. Hope this helps and keeps somebody from replacing cooling fan assembly. ?
A/C cools nice while car is moving (87 here in Orlando) if I stop and idle for a few minutes ac compressor turns off. Car started overheating today while in a car wash line. I let it cool down for about 10 minutes and the coolant temp went back to normal. Drove it home with no stopping and it did fine. I swapped the cooing fan relay with an identical one we never use(Rear window defroster LOL) Anyway neither cooling fan comes on at all. Do I need to replace the whole cooling fan unit or is there something else to test that might isolate the problem? Thanks!
Oh Yeah, issue resolved. And got to say this is truly a GREAT board! I go on other boards for many DIY and other stuff, and this board does truly get to the point to help troubleshoot the problem and resolve it. Thank you folks!
Thanks. That thread says it all. I cant figure out what all these tell me though. Not sure which one to look for..
Mine is a 2012 Edge SLE...I think LOL
manual tilt column. Is the "speed sensitive....intermittent...variable speed?
17A553 (SW-6963)
Window Wiper Switch
With Manual Tilt/Slide Stg Column ; Speed Sensitive Windscreen Wipers; Black
Vehicle Build Date before: 5/31/2013
17A553 (SW-6964)
Window Wiper Switch
With Manual Tilt/Slide Stg Column ; Rain Sensitive Windshield Wipers; Black
or
With Power Tilt/Telescopic Strg Column
17A553 (SW-7037)
Window Wiper Switch
Vehicle Build Date after: 6/1/2013
Like the title says ...the wipers turned to "Off" will stay on most of the time. If we wiggle, turn to high and the off or sometimes hit the washer button and then off it will turn of, but getting worse. I'm pretty sure it's a contact in the control. Anybody have a clue as to what to do? Thanks
Passenger mirror collided with a gas station pole. The housing is fine and not broken or scratched even. The glass and some of behind the glass is broken/missing. It is heated and with memory model. Have been looking for a How To Replace video but havent seen one.
Need someone with replacing mirror assembly to help. Thanks!
Does anybody know where the purge valve is on the 2012 Edge? I've been searching but can't pin it down. Searching the internet that is....the Edge is not here yet. Ok, nevermind found a good video showing just where it is.
Good point Omar302...The oil thing may not be the cause. I'm starting to wonder about a fuel filter. She ran it a couple of blocks at lunch time and it died. started it and made it back to work. She let it idle about 10 minutes and no problem. Any thoughts anybody?
