MyWifesEdge
About MyWifesEdge
MyWifesEdge's Achievements
  1. I have a 2012 edge with 2.0 eco boost engine. The engine light came on last weekend caused by the P0087 code. I took it to the dealer for diagnoses and they determined a bad High Pressure Fuel pump was the cause. The quoted $568+tax to fix which included $300 for 3 hrs of work. I considered doing it myself because that's a lot of money. I got the Chilton's service manual for the car and read thru the procedure which called for the fuel pump and the high pressure fuel line (which runs from the pump to the fuel rail) to be replaced. Nobody - including myself - wants high pressure fuel leak under their hood. I wanted it fixed right, so I decided to let the dealer make the repair. The fix was make and the car runs good, but I found out the dealer only replaced the fuel pump - two bolts and two line connections located on top of the engine. This did not take 3 hrs. My question: Does anyone know if the Ford service manual say to replace this high pressure fuel line? I feel like the dealer cut corners, but charged me for the complete job.
