Tdb921
Everything posted by Tdb921
  1. I have acquired a scrapyard PTU and want to install all new seals and a drain. I'm having difficult time finding these part numbers. Can anyone PLEASE help. The PTU unit i got is marked as AT43-7251-DJ
  2. I've recently developed what im suspecting to be this issue. Lots of nasty sounds when rolling. When this occurred to my wife, she had called me & I had her call for tow & went to get her. I tried to straighten it up for the wrecker that was on the way and it would only roll in reverse about 5 feet before a loud bang & lock up, fwd all sorts of crunchiness sounds. The car HAD been making a slight sound when & after making turns, CV's appeared okay, they and wheel brngs had been done before. I took a chance & decided to change wheel brngs again & test drove after ea side...it seemed to sound better ea time and I was fairly certain I'd got it after both were done. Wife drove lil over a week before this catastrophic fail. Started looking to the rear, saw nothing obvious. The center carrier brng on driveshaft was beginning to tear so I replaced it after finding it CAN be replaced w/o having to replace driveshaft for under $100. While doing this I noticed how bad the lower torque mount (bottom tranny mount) was & replaced it also. It was trashed, but hadnt noticed it being so loose previously, so possible it had recently gave way. Then began research/search for whats really going on?? On stands I ran it w/no drive shaft to find the noise IS in front, was fearing transmission but now feel fairly certain it'll be in the PTU. Gonna repeat that stands test & use stethoscope this time before spending $900 more guessing. Soooo, here's the kicker that'll surely surprise all. We have been planning to get her a new car recently & just hadnt got there yet. Ready for it...this is on a 2010 Ford Edge Sport that now has 230,000+ MILES!!! PTU has never been touched other than how close i got when replacing that lower mount & removing driveshaft!! We are its 2nd owner, but the orig owner was a friend when he first bought it. It had a water pump repl'd by us which was when I found and started having a great mechanic to do all my vehicle maintenance for 1st time in my life....(once I fig'd out where that pump was, sheesh). It's had some front end work; brngs, spindles, ball joints, tie rods, etc. type stuff, done (some repeat even), some issues with the sunroof track i still need to fix & then normal maint. But this is miraculously 1st time for that cooking time bomb thats been lurking. Its been showing signs of a bad CAT thru O2 faults for about last yr. Almost don't think I need to do any further testing to dicide its the PTU. Near hate to put a $900 part in it, but its still a really nice looking car, just with a ton of miles. It would near be painful seeing it be scrapped. I'll do the dorman myself with drain & shield & hope someone can get the good luck as we have with it... After long story, is there easy way to verify seals properly installed when I get the repl Dorman PTU? I'm seeing some seals may be backwards causing leaks. Any other seals/parts I should look at while there (or replace) with this job. I'll try to post once done.
  3. Put up a long post, not sure if it posted or not. Too long to retype now, but in case it shows up.... Can't wait to open this thing. I'll try to post results/pix when done.
