Much like the earlier posts on this issue, my 2019 SEL has started the low speed shudder shifts.  Took it to the dealer (under warranty) and they kept it for over 3 weeks.   After much “evaluation” they’ve diagnosed it with a defective torque converter and low fluid.   They described the problem as :   Defective Torque converter causes fluid to overheat…fluid then pushes out through the electrical connector seal (apparently where the ecm control wires go) and then trans is low on fluid, which exacerbates the shudder symptom.
	Parts on order… they returned the Edge and said it was ok to drive until they get parts.
	Expected arrival of parts is 2-3 weeks.
