KC135GURU
Everything posted by KC135GURU
  1. I have a 2013 Edge with push button start that has an unusual no-start condition. Intermittently the car will not start when using the push button start. I press the brake, then the push button, it cranks normally, starts for a split second, then goes to power off mode (dash shuts down seat retracts). If you are outside the car, you can remote start, get in and it stays running and you can drive off. This car has had the following items changed within the last six months: Fuel Pump Fuel Pump Control BCM PCM the only code the car has in memory is P0457, which I found was the vapor line leaking at the fuel pump that I fixed today. Thoughts?
