Mino
About Mino
Mino's Achievements
  1. I thought this as well, but with the message from ONEDGE16 with a Canadian Sport I assume there is a way even with Canadian vehicle as there should be a dedicated DRL. As for model year and trim level. I have a 2015 Edge SEL, not a Titanium. I did confirm the wiring is same and its just BodyCM programming that determines it, it even lights up the lights on accessory without issue, but maybe there is another setting I need to do for it being an SEL? Would there be another setting I need to edit in FORScan that's blocking writing to block 25 to tell it the type of headlamp?
  2. Thanks for the reply Wubster, I did all those changes and also ensured I am running the latest version of FORScan as well. Still for some reason 726-25-02 won’t let me write the value for HID. It basically says it does and asks me to turn ign OFF and ON again and when I check again it’s still showing as Halogen. I am all for any possible idea as to why that change is the only one not going through. Not sure if my car being a Canadian version plays any factor or not? I'm stumped
  3. Hey @Ghhuff, Trying to do this myself, bought OEM HID headlamps to convert from the halogen to HID for my 2015 ford Edge, I changed the values for 726-45-01 and 726-50-01 based on the above but for 726-25-02 xxxX xxxx xxxx to select Headlamp type from 0=Halogen to 1=HID, when I change the value to 1 for HID and write it to vehicle it says its written and has gone through but when rescanning the car after the change it reflects its still set to 0 for halogen and wont accept the headlamp change to HID. Any thoughts on if you encountered this is or if I am missing something I didnt do for writing to the module that needs to change that hasn't? If I recall its change 726-25-02 to xxxX xxxx xxxx from 0 to 1 for HID 726-45-01 xxxx XXxx xxxx change value at XX to 7F 726-50-01 XXxx change XX value to 10 the second two changes went through no issues but not the Headlamp type. So headlamps work fine when IGN is in ACC/ON position but when engine is on after 5 seconds HIDs just flash and go dark, which is I assume from the change not going through for HIDs for some reason. Any thoughts or maybe I am missing something else you did? Would appreciate any help you can provide.
