koof
    2
Everything posted by koof
  1. Oops I replied thinking this was a different post. Ill keep an eye out and look more into this. Thx.
  2. Currently running 245/60R18 winters and looking to pick up new rims and tires in the spring. With any tire and/or rim size calculator for the SEL trim only shows 18" or lower for sizes but if I select Sport trim I can choose 20's. Should I be safe grabbing 245/50R20 tires and rims?
  3. I know this thread is a few years old but I also have a 2018 SEL and am wondering if a guy could pull the lightbar and tail lights from a sport or titanium and swap to a SEL?
  4. being a computer guy, finally getting a vehicle with a computer and way to eff around with was peak curiosity. So far i have done the following using Forscan: Police Mode locked gear shift - Enabled Double Honk when running and exiting - Disabled Turn Signal flashes when tapped - 6 (increased from the default 3) Seat Belt Chimes - Disabled Door Ajar Chimes - Disabled Key Fob Remote Window Close - Enabled (only remote window open was enabled) Police Dark Car Mode - Enabled Silent Mode on Left Cluster Screen - Added SiriusXM as a media source - Disabled SiriusXM Travel Link - Disabled Climate Section on Right Cluster Screen - Enabled Sync3 Splash Screen - Raptor (changed from the default Ford logo) Auto Door Relock - 30 Seconds (lowered from 45 seconds) the only other things i was going to do in Forscan at this time from what i read were: - add the option to disable DRL into the IPC and enable the ability to do disable (being in Canada its mandatory to be enabled) - remove the turn signal from always being illuminated and only being active when turning (i think i saw someone do this on an earlier page - pg6 maybe) i updated Sync3.0 to Sync3.4 using Synupdater3 from Cyanlabs....such a nicer look and feel. i was also scanning through https://www.fmods.net/ but haven't yet done any mods or app installs but some do intrigue me.
  5. Oh yes I am aware that that would need to be done and can be done in Forscan. Thanks though.
  6. i'll just pick up a set of glossy blacks vs getting them painted as they are beat up over the last 8yrs.
  7. Yep, this is exactly what i am planning out but was on the fence between amber & white but am bending towards the amber. stock chrome rims are still on also, will be getting some nice black rims after winter. stuck on though if i want to stick with the 18's or upsize to 19's. i do work that takes me out on the grids sometimes so i am not sure how the 20's would fare with less rubber on the rough roads.
  8. Sorry I didnt notice the 'Exterior & Body' forum section. Please delete this post or move to the correct location. Thx.
  9. Just joined the Ford Edge club with a white 2018 Sel and am looking for some opinions. Front grill is what i figure is standard oem chrome.....this has to go....gotta go black. I been pulling towards a raptor style glossy black with the big ford letters and am 50/50 with amber and white leds across the top. Thoughts?
