d94
Everything posted by d94
  1. I have a noise I can't figure out. It sounds like a rock hitting the bottom of the vehicle. Sometimes it sounds like it's in the front right other times the rear. It happens usually over 50 Mph and sometime will repeat every 10-20 seconds. It's a 2012 FWD if that makes a difference.
  2. d94
    cylinder numbering
    So to confirm this, 1 and 4 are on the passenger's side and 3 and 6 on the driver's side? I guess this means my misfire on 2 would be the one that is buried at the back not the easily accessible ones at the front. That figures. Thanks
  3. d94
    cylinder numbering
    Can someone tell me the order of the cylinders on the 3.5L or point me to a diagram. I can't find any info on the internet. Thanks
  4. I have the same issue on a 2008. I thought it was the rear license plate as well. That is the exact sound it makes. I don't find mine is at a certain rpm tho, I think it's more to do with the wind. What I think it is on mine is the actually rear bumper, atleast the plastic covering the bumper seems to rattle. If i tap the rear bumper I can reproduce the exact same rattle. I just figured this out, but I have crawled under it yet to see if there is an easy fix.
  5. That answers the glass part and you are right i wouldn't think so either but what if i bought the whole housing not just the glass. Then i would just have to plug in the harness, but i don't know if the harnesses would be the same.
  6. ya, but i'm actually asking if it's possible to upgrade to heated, if you can just plug it into the harness, or if it's a different harness all together. Basically i'm wondering if the car is wired for heated mirrors but the mirrors themselves just arent the heated model. I would love to add heat to my mirrors as the rearview mirror doesn't show alot in this vehicle. and winter in canada pretty much makes your side mirrors useless without heat.
  7. can you put the new heated blindspot mirrors on an 08 sel that doesn't have heated mirrors or do they have a different harness?
