sushi4evo Posted August 4, 2025 Report Share Posted August 4, 2025 I bought a 2009 MKX for parts and didn't count this suv has pano roof and AWD,. to transfer all parts from my already stripped down 2011 Lincoln MKX to convert the newly acquired 09 MKX to a 2011. ECU and everything related but my 2011 MKX is FWD and doesn't have a pano roof, does it need to be reprogrammed? and as for the BCM wiring assembly, can they work on this AWD MKX? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted August 4, 2025 Report Share Posted August 4, 2025 2009 MKX: The AWD system consists of the following: PTU Rear driveshaft 4X4 control module Rear axle with coupling device 2011 MKX: The AWD system consists of the following: PTU Rear driveshaft AWD relay module Rear axle with coupling device 1 Quote Link to comment Share on other sites More sharing options...
sushi4evo Posted August 5, 2025 Author Report Share Posted August 5, 2025 1 hour ago, Wubster100 said: 2009 MKX: The AWD system consists of the following: PTU Rear driveshaft 4X4 control module Rear axle with coupling device 2011 MKX: The AWD system consists of the following: PTU Rear driveshaft AWD relay module Rear axle with coupling device Thank you. I don't really understand anything about AWD or transmissions, but I saw that the 09 transmission vs the 11 ratio is different , and I have no idea, but we'll find out. 1 Quote Link to comment Share on other sites More sharing options...
