Safety Recall 25C39/NHTSA 25V519 - 2025 Nautilus/Mustang/Mustang Mach E - Exterior Lighting Failure
Exterior lighting failure can reduce visibility for the driver and other road users, increasing the risk of a crash.
Light Emitting Diode (LED) Driver Module (LDM).  On affected vehicles, a headlamp assembly’s LDM may fail. A failed LDM will result in that headlamp assembly’s high beam, low beam, position lamp, daytime running lamp and turn signal operation becoming inoperative. For Nautilus vehicles only, a failed headlamp assembly’s LDM also may result in the same-side rear tail lamp, rear turn signal, and rear position lamp becoming inoperative. Inoperative lighting features may result in non-compliance with FMVSS 108.
Vehicles Affected (Production Dates)
Nautilus - Mar 09, 2025 - Jul 24, 2025
Mustang - Mar 04, 2025 - Jul 18, 2025
Mustang Mach E - May 19, 2025 - Jul 15, 2025
1,539 Nautilus vehicles are affected.
808 Mach-E vehicles are affected
19,418 Mustang vehicles are affected
Planned Dealer Notification Date: Aug 11, 2025 - Aug 11, 2025
Planned Interim Owner Notification Date: Aug 25, 2025 - Aug 29, 2025
Planned Remedy Owner Notification Date: Oct 01, 2025 - Dec 31, 2025
Date when VIN will be searchable: Aug 11, 2025
Source: https://static.nhtsa.gov/odi/rcl/2025/RCLRPT-25V519-1620.pdf (above material is extracted from the reference)
