MyFordEdge2014 Posted October 22, 2025 Report Share Posted October 22, 2025 Hello all, my Edge (2014 year model, 3.5l engine) Radiator fan electrical connector ground wire gets burned leading to fan stoppage and engine overheat. 1. can someone help me get wiring diagram of the harness so that I may find and clean the grounding wire connection? 2. what product or replacement part should i use to replace that singular connector (probably coming from the fuse box) to get it going again? not too long ago that I had to replace the fan due to the other side of connectors getting burnt, and had to replace the water pump because of water going to the engine oil system because of poor sealing on the water pump drive. thanks a lot 1 Quote Link to comment Share on other sites More sharing options...
