Todd2299
From the category:
Member Photo Albums
· 11,334 images
  • 11,334 images
  • 1,475 image comments
It was one of the first changes I made. Just cleaned them up, masked off around them and sprayed 4 coats of gloss black spray paint. Thanks for asking!
I like to make subtle changes, like removing the factory badges and then using the black and red EcoBoost badges. One on the rear and one on the lower front corner of each front door. If you look at the rear side pic, you may notice the blacked out centers of the door handles. Used gloss black vinyl tape to cover them since other car doors kept hitting and chipping the white paint. Problem solved. Another touch was  covering the Ford emblems and also using red gloss vinyl tape on the front grill inserts.
  • Thanks 1
I have my Ford emblems covered with a similar thing to yours. My Missus ordered them from Etsy. But, I do like the exhaust tips. Might have to look into that next...
28 minutes ago, onyxbfly said:
I like the subtle red accents! Great job!
Thank you!
Gloss red pinstripe tape on Amazon (of course) it was .236" wide and was a perfect fit. Less than $10 for a 33' roll
4 hours ago, Todd2299 said:
Thank you!
Thanks for the info!
