The oil pressure light will be ON after a stall as there is no oil pressure. The check engine light, also should be on when the engine isn't running.
The fact you had to power down then restart, it may have stored something in the PCM that the dealer can retrieve.
If the oil pressure light is on when its running, you have a problem, shut it off.
Next time you start it, just turn the key on, or push the button without the brake pedal depressed, you should see those two lights on.
