hamman
Everything posted by hamman
Has anyone tried to install HIR1 or HIR2 bulbs in their Edge? I have a 2007 Edge SEL and would like to improve the output of the lead lamps but HID's are to much trouble. I know that the HIR's would have to be modified to fit but I am worried the bulb may be to long and hit the reflector shield. Any info on this will be appreciated.
What is a rebuilder?
I think this has been mentioned before. Three times since owning a 2007 Edge when starting of from a standstill after starting the engine the tranny is in a higher gear (maybe 3,4,or5). I stop and restart engine and shift into DR the tranny clunks into gear and then everything is ok. This has nappenned 3 times in 32000 miles. Of course the dealer states everthing is ok. My warranty is up next month.
I have Conti's on my 2007 Edge with 30,000 miles. The tires have plenty of tread left but they are very noisy and getting worse day by day. I would never buy these tires. Only way to go is Michlin LT's
I have 23000 on my 2007 Edge. The Continental tires are getting noisy (road noise). Plenty of tread left but will probably replace with Michilin Latitudes soon.
My Edge has just under 11,000 miles and to early for transmission oilchange. The problem appears to be tempurature related. It is more noticeable when temp is 90 or more. The dealer tried to set the tranny "learn" feature back to default but it had no luck.
My 2007 Edge FWD will not shift into 6th gear until speed reaches around 60 MPH. (under slow Acceleration). This occurs after vehicle has been driven for 20 minutes or so in hot weather and then parked for a while and then back onto highway again. (always hot in SW Florida). The dealers diagnostic test showed no error codes, therefor no problem even tho tech witnessed problem. The tech called the Ford hotline and they claimed this was normal. Anyone in the forum having this problem?
I have been buying my gas at Costco here in Naples, FL. A few months ago there gas pumps started advetising 10% ethanol. My gas mileage dropped form 19 to 17 around town with some highway mixed in. Ethanol is for the birds but the tree huggers love it. I am going to try Shell or Mobile and check the difference. Also the on board gas computer is not accurate and tends to inflate the mileage. The only accurate method is to divide actual gas usage into actual mileage.
I have a 2007 Edge, 2 wheel, 18 inch tires and no sunroof. Here in FL most driving is done with a/c on. Have been gettin 18-19 mixed driving and on a 3400 mile trip (Boston & back) I averaged 23-24. Speed up to 80 at times but mostly 70-75 This was in December so no a/c. Lately the mileage has dropped 1-2 miles per gallon. It could be a change in "summer blended" gas. I buy most gas at Costco. Also have noticd the transmission shift points have changed and does not always shift into 6th gear. Ford states this is temperature related which I think is bull. Will be going back to dealer again soon. Costco and Sams have signs on there pump that read 10% Ethanol added to gas. I know this also lowers mileage.
My 2007 edge has banged into 2nd gear when accelerating away from traffic light after easing up on the pedal and then hitting the gas pedal again. This has only happened once. Also have tranny slipping when shifting from 5th to 6th gear. The rpm increases 500 rpm and then drops back to mormal after a second or two. This started at 6000 miles and now have 9000 miles on the Edge. Will be taking to dealer in a week or so.
2007 Edge Sel+ FWD with 7000 miles. Transmission slips when shifting from 5th to 6th gear. The RPM's increase 500 RPM and then drop back to normal. The slippage lasts 1-2 seconds. This problem appears to be getting worse as time goes on. Anyone else had or having this problem. After a few more weeks I will be taking Edge back to dealer.
2007 Edge SEL+ FWD 7000 miles. Average for city driving is 18 MPG. Highway average is 23 MPG. The computer mileage is about 1 1/2 MPG higher which is of course erronious. This mileage is much better than my previous 2004 Durango.
SIDE MIRRORS QUESTION
hamman replied to Poorboy's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Yes, both mirrors swivel inward! -
My last two vehicles had tinted glass and the MFJ Dual Band antenna worked fine. I don't believe the tinted windows in the newer vehicles contain any metal compounds. I mounted the antenna on the drivers side rear (small) window. The transceiver is under the rear seat and the control head is mounted in the cubby hole behind the shift lever. The radio is wired back to the power module (cigar lighter plug) in the rear of vehicle. It would be better to run the wires direct to battery which I will do some day. Good luck with your installation 73
2007 Edge SEL+ FWD with 5500 miles. Just got back fro 1560 mile trip, mostly highway and averaged 24 MPG on the computer. Average sdeed was 64 but pushed 80 occassionally. Around town aveage is about 15-17
2007 Edge SEL+ FWD I am a ham (NN1NN) but have US ARMY vanity plate. I have "thru the glass antenna" mounted on drivers side far rear window. Of coarse it is only 1/2 wave but is sufficient for VHF and UHF
2007 Edge sel+ FWD Just drove from Boston, MA to Naples, FL 1560 miles I am 71 yrs young, 6'2", 180 lbs and found the leather heated seats very comfortable. I made the trip in 2 days (14 hours each day).
Nothing is legal in Taxachusetts. I used to live there. Live in Florida now; everything is legal!
The vehicle still pulls slightly to the right. Most noticeable at high speed. I wonder if it is caused by transaxle torque. This vehicle follows the crown of the road more than my AWD Durango did. I have a 3500 mile trip coming up in November and I want this beast in top shape!
Picked up my Edge at the dealer today. The oil leak was caused by a faulty oil filter adapter o-ring. There was a metal shaving in the o-ring. They also performed TSB-07-7-6 on front end due to pulling to the right. Wonder what is next!
My Edge with 300 miles on it went in for engine oil leak a few days ago. They gave a rental car to use (Ford Fusion). Not a bad car but it is a 2006 and the interior is dirty and stained. If the vehicle is not fixed in a couple of days I will return the rental for somethig better. It appears from what I have found on the various forums Ford Edges have quality problem. Florida has a good Lemon Law which I will be looking into.
I took my 2 week old Edge in to dealer for engine oil leak. They gave me a rental car and said they would find out where the leak was. This should not happen with a new car and I am concerned about poor quality control. They have already performed the TSB for the "pulling to right" problem but as I have not driven it yet I am not sure whether that problem has been fixed.
I thought the "pulling to the right problem" was fixed but have noticed that at high speed there is still pull to right. Also engine has developed slight oil leak around the oil pan or oil filter. It is going back to dealer in a few days. I am not a happy camper. Second trip back to dealer in two weeks. Hope I did not get a LEMON.
Picked my Edge last week. NN1NN is the call here and will be installing "through the the glass" dual band antenna. As it is a half wave antenna, no ground plane is needed. Not as effective as 5/8 wave but is better than nothing.
Took Edge into dealer today for front end alignment. The tech stated the toe in was out of adjustment. It appears the "pulling" problem has been corrected. I have noticed that the vehicle has more tendency to wander in direction of crown slope than my previous Durango which had AWD. This appears to be normal for this Ford vehicle which is FWD.
