willie88
Everything posted by willie88
  1. Great information guys.... Yes Ford wont take any responsibility for this major safety issue !!. Had my 2018 Edge Titanium horn measured against 2017 fusion , 2017 Edge and a 2012 Edge and my horn is -10DB lower in volume. That's 4 times (4) less than other REAL car horns. Question : I assume that the FA1Z-13832-B WILL FIT MY 2018 TITANTIUM ? Think the video showed a 2018 Edge SE ? Thanks everyone !
  2. 2011 Ford Edge , V3.0.2 was installed a few months ago from the Ford Flash Drive that was received in the mail without any problems. GREATLY NEEDED update , interface was made simplier , HOWEVER . Seems that the reboots are well hidden after the ignition is turned off . With the radio turned off , there have been a few times that when the ignition is turned off and the door is opened , the radio comes on !! Tried to close the door , turn the ignition back on , radio control is lost , and I just leave the volume low and eventually it times out ... Maybe with a reboot. Removing the outside temperature for the center display is a BIG MISTAKE..... What do I need another compass display for ???? You can hardly see the temperature (gray very small font) on the drivers display !! What did the large 'beta tester ' group look for when they were checking the overall funtion and ergonomics ?? Still not happy , V3.0.2 is NOT STABLE AND IS NOT PRODUCTION ACCEPTABLE YET !!
  3. Had my 2011 Ford Edge for about a month. The Sync/MFT software version is V2.7. Have all sorts of troubles that include : Radio turns on if you use any Sync function, clock changes time intermittently , " where am I " reports a Longitude that is 75 miles to the east , sirus browse function takes minutes to load ( if ever ) and if you access it again , it resets itself and starts the " loading" process all over. I'm told that TSB 110418 resolves most of these problems ( and a lot more ) , however when I went to Ford dealership , their computer system told them that this TSB has been " withdrawn" and is not available for the 2011 Ford Edge.... Well , calling Ford Tech. Support again.... they told me that they had major DataBase problems and that TSB 110418 ( which includes upgrade to V2.8) needed to be installed however they needed to fix the DB problems first... Called them today and the problem is sill not resolved ....... WOW , I really like my 2010 Fusion Nag and SYNC system , but this new software is really buggy !!!! ANYONE HAVE INFO ON WHAT TSB 110418 AND V2.8 FIXES.. MOST DECENT COMPANYS PROVIDE REVISION SUMMARYS !!!!!
