Jocelyn Castro
Facebook Member-
Everything posted by Jocelyn Castro
so meaning, i need 63.4mm id to 70.5mm od rings then i can fit the trak+ plus wheel spacers cause thats 70.5mm cb. since i have an aftermarket wheels wheels that has 73.1mm cb ,i also need 70.5mm to 73.1mm rings? is that correct?
im just wondering if this item will fit on ford edge 2013? ive read some post here that edges 2011-up has 63.4 center bore. on h&r website says that their wheel spacer will fit on 2007-up (70.5mm cb) . need help. thanks http://www.hrsprings.com/application/search/results/11/249/2013
H&R Springs Front Springs Upside Down?
Jocelyn Castro replied to Nikos33's topic in Brakes, Chassis & Suspension
ohh i see.. whats the wheel offset? i already installed my h&r lowering kit but it seems the front seems less drop than the rear, i measured the front and its 4" gap, rear hAs only 3" gap. i love how it drops the rear, then i saw your other post, that you remove the rubber insulator on the front, im afraid to remove that, might negative effect happens in a long run???? yours still good? , my friend said if we remove that rubber might damage the strut? and will make some squeking noise when turning? is that true? is that tire and wheel set up good also for winter? cause i dont wanna do change overs every winter/summer. -
hi, i saw the other thread you started about the aftermarket wheels. i just have some questions, did you use adapters so theres is no rubbing? looks good man. -
a local retrofiter here in canada, its called winnipeghid.
hi guys, i need some help here. i have an edge 2013 limited with 20" chrome clad wheels. i just sold the whole set las week. then i have a new set of aftermarket rims coming in this week. anyone here knows how to train the after market tpms sensors on my car? or do i still need to train them?0r it will pair automatically? thanks in advance.
so it means i got lucky cause i sold mine for $1500 ., now im looking for an aftermarket wheels. im eyeing on xix 21 exotic wheels, 20x 10. any recommendations on the tire size? i checked it out with 265 /45r 20. will this fit on edge limited 2013? without rubbing on the fenders? the person im buying from suggested 255/45 r20, but i want more wider. i checked tru tire size calculator 265/45r22 (sports model). has the same width as 265/45r20. suggestions guys? thank you
yes it is. im selling the whole thing with tires. plus the tpms sensors . i only used them for about 22,000 km. $1500
need an advise, im gonna sell my oem set of wheels for $1500. and gonna buy aftermarket ones. do you think is that ok?
Noise from dash area
Jocelyn Castro replied to EspoMan's topic in Interior, A.C., Heat, Interior Trim
same problem here! i have 13 edge limited . -
Ford Edge Vertical LED DAYTIME Running Lights - IN STOCK
Jocelyn Castro replied to kc300c's topic in Classifieds
i really wanna buy this, but i have my front turn signals act as my drl. i have a canadian edge . any one can help me with the wirings?- 31 replies
- bumper strip
- bumper led
- (and 8 more)
canadian drl hid
Jocelyn Castro replied to Jocelyn Castro's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
figured it is better that it has 50w resistors. ive notice without resistors led's were flickering. -
canadian drl hid
wizard. i installed the led lights that i showed to you, its working fine, i just change the bulbs, and i dont need to put the resistors. or i still need to put the resistors? -
canadian drl hid
i'm just gonna add $100 and its already an EDGE-2 . and in 3000 kms my edge needs an oil change. hoooooooo. so im not thinking any upgrades for now. -
canadian drl hid
wth. dealer charge me too much ($146) just to change my dlr from headlights to front turn signal. didnt expect it'll cost me that much! -
canadian drl hid
http://www.ebay.ca/itm/271153815801?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 this is the item i bought from ebay. http://www.ebay.ca/itm/271153815801?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 so do i still need to wire resistors right? can you help me where to wire the resistors? thanks. -
canadian drl hid
sounds good. i have another question. my front turn signals now is my drl. can i still switch it to led switchback bulb??? i just ordered the item from ebay, its 3157 led switchback bulb. -
canadian drl hid
norm, so if i didnt change my drl (from headlights to front turn signal) it will be easy for me to install the edge2 and act as drl?? then go to my dealer and ask them to turn off my drl (headlights)? cause i have an appointment tomorrow to change my drl (headlights to front turn signals) for me to install hid kit. -
canadian drl hid
thanks for the info. actually im not good at the wirings, is there a video or pictures that i can watch so it'll be easy for me to do it? im planning to have edge2 nxt year summer, cause i just owned my edge ,3 months ago and im still enjoying it. where do live in canada? winnipeg? -
